Team Associated RC10B64 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree710Likes
Last edit by:
Print Wikipost
Old 09-18-2017 | 11:13 AM
  #2626
I'll try again, what spares should I keep on hand for this car?
TRIPLE 675 is offline
Old 09-18-2017 | 11:16 AM
  #2627
Wildcat1971's Avatar
Tech Prophet
arms, towers, gear boxes and spur
windycityblues likes this.
Wildcat1971 is offline
Old 09-18-2017 | 11:43 AM
  #2628
Thank you
Old 09-18-2017 | 12:42 PM
  #2629
Just finished the build for my first B64... it was a pleasure to build it... just front end uper and steering links when I build per manual...their length where completely wrong
Installed electronics -plenty of space for all, after schumacher K2, also this is a nice option.
But when made the first meters... that noise confused me... noise from drive train... is it a norm for B64?
What the first steps to reduce it?
After K2 this things seems like a nitro for me
hardijs is offline
Old 09-18-2017 | 01:13 PM
  #2630
LA-2-AL's Avatar
If it is run what you brung, I would try a 10.5 or 13.5. 17.5 might be a bit under powered.
If I stick with the class then yes, I'll probably upgrade the motor,, the 17.5 was what the guy threw in the deal to get me started
Originally Posted by rigor
FYI with the 81 spur I don't believe you can fit a pinion any larger than a 29 tooth (can anyone confirm?). Not sure off the top of my head with the 78 spur, but I'd guess its not more than 30 tooth fitment. Running 17.5 in 4wd usually has required custom made small spur gears.
Thank for the info I was a little worried about that too, I was going to pick up a 28 to start, I'm going to pull it apart and confirm the 81 or 78 before I do anything,, I assumed it was a 81 because I thought that was the stock gear,, but I'm not 100% sure because I bought it assembled.
if the 17.5 isn't really workable,, well I know what to do.
tnx
LA-2-AL is offline
Old 09-18-2017 | 01:42 PM
  #2631
Tech Prophet
If the guy tossed in the motor, it may be a wore out motor, or an old motor design. Hence the slower speeds.
Old 09-18-2017 | 02:21 PM
  #2632
I had a YZ-4 before this. This car will always be noisier than a belt but this car does have a bit of a reputation for being noisey.
I have an early edition before changes were made to the ring gear. I tried mine outside the house and thought it a bit loud but when i took it to the track I felt it was no louder than anything else.
As said many times before, pay particular attention to shimming the diffs. The manual calls for 5 and 3 shims on the diff. Many people reccomend 8 and 0, but I found the manual to be spot on.
Moral of the story, do it for yourself, ignore recommendations of how many shims, but pay attention to recomendations on how its done.
Best of luck.
hardijs and John Myall like this.
Piles is offline
Old 09-18-2017 | 06:34 PM
  #2633
RCBuddha's Avatar
Red RC ? RC Car News » T-Works B64-series aluminium centre driveshafts
RCBuddha is online now
Old 09-18-2017 | 07:23 PM
  #2634
PorTX's Avatar
Wonder how the weight savings would stand up to the abuse of a 5.5 - 7.5 motor on carpet?
PorTX is offline
Old 09-18-2017 | 10:38 PM
  #2635
rgrg2's Avatar
Default Shocks
Is anyone using the longer rear shocks and shock tower on the B64D?
Are the orange O rings necessary in the center outdrives?
rgrg2 is offline
Old 09-19-2017 | 05:26 AM
  #2636
LA-2-AL's Avatar
Poor choice of words on my part,, it wasn't a freebie,, I bought the motor,,
LA-2-AL is offline
Old 09-19-2017 | 09:49 AM
  #2637
rvrslt1's Avatar
Any idea how this may work with the MIP and plastic dif gears?? Running on clay.
rvrslt1 is offline
Old 09-19-2017 | 11:10 AM
  #2638
I run the longer shocks and tower with vrp valve pistons, chrome shafts and machined internals. It has really helped keep the back end stable on a very bumpy loose track. If your track is bumpy I would say it's worth it. For smooth Clay I wouldn't bother.
I run with the orings but wouldn't say it's necessary. I have never run without them to see how close it is to having the drive shaft pop out from the center outdrives.
E-Mann is offline
Old 09-19-2017 | 11:21 AM
  #2639
The O-rings help prevent the pins on the dogbones from hitting the G-clip and ejecting them. If you switched to snap rings, it doesn't matter.
Krio is offline
Old 09-19-2017 | 02:26 PM
  #2640
I run with the long rear tower + shock body on indoor bumpy clay and it helped settle the rear of the car significantly. All of the "fast" local AE drivers run long rear towers at our track.
daedalus is offline
