Team Associated RC10B64 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree710Likes
Last edit by:
Print Wikipost
Old 08-29-2017 | 07:11 AM
  #2491
Originally Posted by jabroni racing
Just a heads up, I bought the asc1370 servo horn as suggested in the thread & it doest fit 100% to give full steering lock. I have my savox 1258 with no spacers so its as far back as possible but It hits the steering post so I had to shave the back of it on a angle a couple of mm's. Before shaving it i thought i had full lock but realized it was hitting the post & actually making my servo flex in the mount..
Weird - I run the Savox 1258tg with the exotek servo horn with no problems
youngrigo is offline
Old 08-29-2017 | 08:24 AM
  #2492
jabroni racing's Avatar
the exotek has less width where the ball stud goes through then the AE on, here is the exotek, the AE has double that thickness so I had to grind it
jabroni racing is offline
Old 08-29-2017 | 10:21 AM
  #2493
I'm pretty fond of the 1363 part, I removed the 1mm shim on the bellcrank and had to relieve maybe another mm or so on the front brace. This also clears the PL body
Brian Bosley is offline
Old 08-29-2017 | 07:25 PM
  #2494
ravage's Avatar
Going to finally finish the build tomorrow, I haven't been in a rush since I haven't really had or will have time to go to the track. The people at the place I'm racing at are all suprised that there is another associated, there's tons of losi cars.
ravage is offline
Old 08-30-2017 | 02:56 AM
  #2495
Default Servo horn?
Hey guys. Looking to take the plunge on a B64 and Im reading the thread about servo horns. Does anybody use the associated clamping horn? If not is there a reason not to.
https://www.teamassociated.com/pictures/products/1370/1370_md.jpg
Piles is offline
Old 08-30-2017 | 04:02 AM
  #2496
Jon Carlson's Avatar
Regional Moderator
https://www.teamassociated.com/pictu...70/1370_md.jpg
I use that and like it a lot. You won't be disappointed.
Jon Carlson is offline
Old 08-30-2017 | 04:25 AM
  #2497
Thank you Jon. I think I miss read what went before and realise now that is what people are recommending.
Piles is offline
Old 08-30-2017 | 04:29 AM
  #2498
Default What spares should I put in my pit box?
Coming from a Yokomo and thought Id give an Associated a go after being reccomended. Ive been told its easier to drive on high grip astro. I have read that the arms and possibly the gear boxes are good to have and build it with the aluminium streering rack and servo horn. Anybody breaking anything else?
Piles is offline
Old 08-30-2017 | 04:52 AM
  #2499
celt's Avatar
Building my B64D now.
Using the Reedy RT1508 servo with the ASC1370 horn. The Savox must have a more forward dimension - after mounting everything up, I'm a solid 4.5mm-5.0mm between the closet part of the horn and the steering post.
Reiterating that the Reedy RT1508 / ASC1370 is a working combination.
celt is offline
Old 08-30-2017 | 08:11 AM
  #2500
RCBuddha's Avatar
Red RC ? RC Car News » RDRP B64 aluminium differential cases
RCBuddha is online now
Old 08-30-2017 | 08:17 AM
  #2501
RCBuddha's Avatar
Red RC ? RC Car News » RDRP B64 aluminium battery posts & thumb nut
  #2502
EbbTide's Avatar
I'm not a big associated guy but dang those diffs look sweet
EbbTide is offline
Old 08-30-2017 | 08:49 AM
  #2503
see my post 3 up from yours. LOL
Old 08-30-2017 | 09:06 AM
  #2504
Thanks I didnt read that properly I thought it reffered to an Exotoek pt.
Piles is offline
Old 08-30-2017 | 09:17 AM
  #2505
I would've got the exotek one if I new, Honesty it was a whole 2 minutes with the dremel so I don't care, but wanted to share..
