Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 08-22-2017 | 12:02 PM
  #7201
Does anyone know the effect that running 2 spider gears in the gear diff vs running all 4?
Kelseyrc is offline
Old 08-22-2017 | 01:44 PM
  #7202
JsK's Avatar
JsK
Little better rotation on the way in and a little better on power steering on the way
out.of corners. It seems most popular on high grip astro and carpet.
JsK is offline
Old 08-22-2017 | 03:03 PM
  #7203
czrlaker's Avatar
I kmow the stock guy's do this and love it. Is it doable with mod? Don't wanna mess any gears up.
czrlaker is offline
Old 08-22-2017 | 04:41 PM
  #7204
I am going to try to run my diff with just 2 gears tonight with a 7.5 on astro. And I'll report back the results.
Kelseyrc is offline
Old 08-22-2017 | 09:58 PM
  #7205
I've ran 2gears in my diff with 6.5 on astro for a while and it holds up just fine. Its a good compromise between 4 gears and a ball diff.
Mi4cxl is offline
Old 08-23-2017 | 06:19 AM
  #7206
Did you go down on the diff fluid? How was the on power steering? I have had to run 10k at our carpet track to keep from diffing out with 4 gears. Going this high in diff fluid has hurt my rotation. I am going to be playing around with 2 gears as well. Any ideas where to start with fluid weight? Running 7.5t on tight high grip carpet.
dinosback is offline
Old 08-23-2017 | 08:07 AM
  #7207
Can anyone recommend an easy to drive setup that uses slicks? Track is super hard packed grooved and bumpy. Or anyone got the nats setup? Thank you
Cday is offline
Old 08-23-2017 | 08:53 AM
  #7208
I just ran my diff with 2 gears last night on medium to high grip bumpy astro and really liked the feel. To me, the rotation was much better throughout the turn and I was able to get back on the throttle a lot sooner and my average lap times went down by a tenth or two.
I used 5k oil in the diff and it felt really free without diffing out. I might try to go up to 6k to see how that feels but for me there was definitely improvement with using only 2 gears.
Also, I was running a 7.5 and there wasn't any durability issues for me.
Kelseyrc is offline
Old 08-23-2017 | 12:21 PM
  #7209
Old 08-23-2017 | 02:33 PM
  #7210
lexusbest's Avatar
Rebuilded my diff to 5k 2gear. Will see how it goes with 8.5T on a outdoor high grip bumpy astro track
lexusbest is offline
Old 08-23-2017 | 02:52 PM
  #7211
Let me know what you think of it, I'm interested to see if you found the same thing that I did.
Kelseyrc is offline
Old 08-23-2017 | 10:55 PM
  #7212
monkeyracing's Avatar
When you install the alloy front bulkhead, are you meant to reuse the steel plate that goes across the front of the plastic version? There aren't any instructions but this seems logical to me.
monkeyracing is offline
Old 08-23-2017 | 11:21 PM
  #7213
Yes. You are correct.
Still Bill is offline
Old 08-24-2017 | 12:41 AM
  #7214
Thx. I was going to use a few 1mm shims, but this was far easier.
Old 08-24-2017 | 03:55 AM
  #7215
5tone's Avatar
I'm riding with this configuration (7k in the diff) since a year now
And I'm pretty happy with it
5tone is offline
