Like Tree18Likes
Tamiya TRF102
Old 08-08-2017 | 05:12 PM
  #406
dmcguire's Avatar
Originally Posted by mleemor60
If you have ever picked up a good CF splinter off the edge of a chassis or any piece for that matter you wouldn't have to ask that question.
I've been on the receiving end of plenty of those over the years.
The pictures I've seen of other cars did not look like the edges were done. Wasn't sure if there was a reason other than not knowing to do it, not wanting to do it, or that it shouldn't be done for a reason.
But going to do it anyways.
dmcguire is offline
Old 08-08-2017 | 05:14 PM
  #407
Kevin CBR's Avatar
Originally Posted by aracefan
Ebay? Why don't you just get the new black version? I mean, are you just wanting the blue anodizing?
I'm thinking of picking up the black one just so it's NOT the blue.
And sorry, don't want to sell the 102.
And Robinson.
I have a NIB and sealed TRF 102 black version, F104 V II Black Edition and F104w GP if you are looking to itch that non-blue Tamiya scratch.
Panda 🐼
aracefan likes this.
Kevin CBR is offline
Old 08-10-2017 | 06:26 PM
  #408
ShadowAu's Avatar
Originally Posted by dmcguire
Hi all,
Just got a hold of one of these guys and very excited to try F1. Was wondering the consensus of sanding and sealing the chassis edges with CA? Would always do this with CF sedans, but wasn't sure on this car. Figured it may help stiffen the chassis some and at the very least it will look pretty.
Thoughts for or against?
I always sand and seal any CF chassis regardless of class. I doubt that it has any serious impact on chassis stiffness but it does help stop the edges splintering etc.
Maybe if was going to be a shelf queen and never see a track I MIGHT leave it as is from the box
dmcguire likes this.
ShadowAu is offline
Old 11-16-2017 | 06:31 AM
  #409
101 and 102 parts lots
http://www.rctech.net/forum/r-c-item...amb-roche.html
xps800doo is offline
Old 06-23-2018 | 10:40 AM
  #410
fat500's Avatar
This is the most consistent f1 chassis I have run to date. looking for the caster settings anyone have a chart. tks
fat500 is offline
Old 08-20-2018 | 02:50 AM
  #411
I'm now running my TRF102 on asphalt and wondering about the best front end for it. I have the narrow standard one and the F103 wide front. I had it setup with the F103 front and 103 wheels for carpet but have stopped running that now and just running asphalt.
I need new wheels and tyres as we were running foams. I was planning on getting shimizu 575 rear and 573 fronts, but could pick up F103 rubber if thats better.
Is the narrow front end the way to go?
Or should I get the shims to adjust ride height on the F103 front to run F104 wheels.
jgil089 is offline
Old 08-20-2018 | 07:04 AM
  #412
fat500's Avatar
I would rebuild the car put it back to stock settings using the medium t-bar or the carbon fiber berserk one. Since you are switching to Asphalt I would start fresh this car will tear it up on an asphalt surface with the stock settings the only thing you will really need to change is the rear spring play with the Lube in the rear damper and adjust the front Springs I would use pit 571 572 combo works the absolute best especially Outdoors. I would definitely use the kit front end that came with it and if you want to change the steering characteristics mess with the tie rod outer ball settings on the front upright start on the outside closest to the rear tire and move the ball stud in if you want the car to be more aggressive you can also use the trailing axle as opposed to the inline axle on the upright trailing will make the car a little easier to drive and smooth it out depending on your surface this car is fast I have been racing it for a while it is extremely smooth and predictable if you've been using your front springs for more than 2 or 3 months they tend to wear out if you took a used one off and compared it to a new one you'll notice it's about a millimeter shorter so that's something that can mess with the handling overtime make sure you put on new front Springs every 2 or 3 months have fun good luck this car loves asphalt
Fran and jgil089 like this.
fat500 is offline
Old 08-20-2018 | 07:07 AM
  #413
fat500's Avatar
I usually use Tamiya tires 1031 and 1032 they are the same as the pit 571 and 572 they are just sold by Tamia and have a TCS logo on the side of the tire TQ racing stocks them and they mount to the f-104 foam Wheels TQ actually has a nice tutorial on how to mount the tires to the rims online.
jgil089 likes this.
fat500 is offline
Old 08-20-2018 | 12:32 PM
  #414
Thanks thats great advice. I will rebuild back to stock and go from there. Luckily I have a few sets of kit front springs so will check them out. This car only runs once a month, weather permitting, as thats all the racing around me. I could run twice a month if I run indoors and outdoors butnhave decided on outdoors only.
One question reharding the tyres - are 571/572 the best combo with sauce or still good without it? We can't use tyre sauce. Also, the track is setupon netball courts so it can be really dusty at times which is why I was leaning towards the 575/573 combo, more stable and less steering. Its easy to swap ends...
jgil089 is offline
Old 08-20-2018 | 03:15 PM
  #415
ShadowAu's Avatar
I tend to use 573/575 on a similar surface to yours without sauce and it works pretty well. I race at night and its usually pretty cool as well. I would only look at 572 if the temps are higher but if they are really high then swapping to Ride rears usually works for me.
ShadowAu is offline
Old 08-20-2018 | 06:52 PM
  #416
Great thanks. I'll try the 573/575 to start and then as we get into summer (I'm in New Zealand so its winter right now) will look at the 572/571.
What Ride rears are you talking about? The GR? I can get Ride R1 cheap at the moment, its tempting to get them to try out but no point if they aren't any good
jgil089 is offline
Old 08-21-2018 | 03:20 PM
  #417
ShadowAu's Avatar
I wouldn't go for 571 fronts unless you need a lot of steering. Even if the temp came up I'd be tempted to stay with 573 fronts unless they just didn't balance the way you want.
I use R1's simply because i have a supply of them left over but they do the job for me. I believe the GR's do a similar job just more robust. I've been informed that the Gravity F1 tyres are rebranded Ride tyres
jgil089 likes this.
ShadowAu is offline
Old 08-21-2018 | 05:00 PM
  #418
F N CUDA's Avatar
didn't post in for sale section but I've got a like new TRF 102 with the $$ option carbon fiber front end as well as standard front end.
$200 sound fair? same price if pick up or ship, I got someone who can ship
text me for pix if interested
949) 533-3466
F N CUDA is offline
Old 08-21-2018 | 10:11 PM
  #419
Great thanks. I should probably grab the R1 rears then while they're cheap but stick to the 573s for the front.
ShadowAu likes this.
jgil089 is offline
Old 09-09-2019 | 11:51 AM
  #420
Hello, has anyone tries the exotek front top arm conversion for the TRF102? Any benefit?
DK9mm is offline
