Team Associated B6 & B6D thread
#7081
Just ordered 4600 graphene 90c. https://hobbyking.com/en_us/graphene...connector.html See if it helps. 52 to door bay of e. Thanks
#7082
#7083
For oil, I have some lightning high speed oil from Boca bearings, but any light oil meant for bearings will do. It's all lower drag than the grease that comes packed in most bearings.
If you need new bearings on a budget, get the $1 metal shielded ones and clean out the grease the same way and re-oil.
#7084
Pop the seals, motor spray (but I use an RPM bearing blaster)
I soak mine in Marvel Mystery Oil overnight.
Then needle lube with a bicycle chain oil, old school rc stuff that smells like bananas I believe it's Tri Flow Super Lubricant
But honestly.....I just buy Avid's for a buck a piece and I've been replacing for a while now
#7089
The xrings with the machined shock spacers. In my opinion the xrings don't last as long as some others out there. Haven't found a suitable replacement though.
#7090
Ok I found them. Love the guys review. Not sure how AE gets away with the factory orings? There a sheet sandwich. Hope these help a bunch. I am seeing visions of a losi or d216 in my future. (FYI it's how stuck the orings are on non moving shaft. Tighter than a turtles pelt.) But whatever. https://www.amainhobbies.com/team-as...BoCC4cQAvD_BwE
#7091
Ok I found them. Love the guys review. Not sure how AE gets away with the factory orings? There a sheet sandwich. Hope these help a bunch. I am seeing visions of a losi or d216 in my future. (FYI it's how stuck the orings are on non moving shaft. Tighter than a turtles pelt.) But whatever.https://www.amainhobbies.com/team-as...c91495/p275244
And this: Machined Spacers
I also don't like to use anything other than shock oil on the seals...no green slime, blue protek stuff....just shock oil. The factory O-rings in the new kits are the x-rings...they just don't include the machined spacers. The molded spacers can pinch the rings and bind (especially if you tighten the lower cap) because the tolerance of a molded part isn't the same as machined.
#7092
I have been running the shiny pucks with rollers. Both gear and ball diffs. I'm pretty happy. I ordered a silly amount of rollers when I thought that MIP wasn't making them anymore. I'll be using them for years.
#7094
5 series shocks are the same as the B6 shocks. All the shock bodies for the 5 series are the v2 so yes they work. I use them in all my shocks... T5, sc5, 64, B6
#7095
I've just opened a set and discovered that they only come with four of the hat-spacers, whereas the B6 kit uses 8 of these. The ASC91494 comes with another 4 round spacers. Rather than try these, I used the stock spacers in the front shocks. I'd suggest getting two packs if you want to use the ASC91494 unless someone can confirm they work without using 8 hat spacers.
653Likes
