Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1386Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 07-18-2017 | 08:04 AM
  #1471
Originally Posted by 2hundy
Would a 26t pinion fit with a stock 70t spur? 25t to 26t is an increase in diameter of 0.8mm so the pinion-spur distance is 0.4mm closer with the 26t. In my experience tamiya motor mounts provide a relatively loose mesh, certainly looser than I would set on my BD7.
I'm entering a stock spec class where only the pinion can be changed.
You could try...and see if you can turn the wheel freely...the stock motor mount only up to 25t pinion for 70t spur.
0.4mm gear mesh seems a lot to me as I usually left a paper thin gap between spur and pinion which should far less than 0.4mm
MajorRex is offline
Old 07-18-2017 | 09:07 AM
  #1472
Tamiya's predefined mesh is usually on the loose side, certainly more than just paper thin. Maybe this is still the case on the TT02?
Has anyone tried a 26t pinion?
2hundy is offline
Old 07-18-2017 | 10:45 AM
  #1473
lilws6's Avatar
Just picked up a tt02r last week from the local shop. They run some outdoor races in the parking lot that I want to attend. I've read about 86 pages of this got some good information going forward with the car. I plan on running 17.5 vta series ( they do vta a little different apparently) possibly drift the car a bit as well. I'm in the process of building the car now. Been taking pictures every page or so while building it. Body is a McAllister 1970 trans am. Waiting for decals on that. Still need tires for my vintage wheels. I've ordered a few bits and pieces from tamiya USA that should arrive this week. Going to at least get camber adjustable on the rear. Also doing the body posts on the front bumper as that's what I'm used to when I used to race indoor carpet many years ago with my tc3. So far I am very impressed with the kit. Very easy to build and definitely good quality. I'll have to post up some pictures of my build when I can 😉
lilws6 is offline
Old 07-18-2017 | 04:27 PM
  #1474
I've been working on a couple of TT-02 kits myself. I just finished the Motul Autech GT-R. I'm almost finished with the Mercedes-AMG GT3. Just have to finish the headlights, taillights and the wing.
They were both really fun builds!
DoubleRR24 is offline
Old 07-18-2017 | 05:07 PM
  #1475
Just started racing this summer in the novice class. Chassis of choice is the TT-02 Type S, with the NSX body. I started out using NiMH and a brushed motor and have been finishing 3rd. The top two are running brushless systems.
Last race of the summer is coming up this weekend and I've upgraded to brushless myself. We'll see what the results are.
Here's my equipment:
Reedy Sonic 540-M3 25.5 ROAR Spec motor
Hobbywing XeRun XR10 Justock ESC
Gens ace 500 mAh 50c 2S1P battery
Radio is the Futaba 3PRKA (hope to upgrade to the 4PX or 7PX this fall)
Upgrades/Hop-Ups:
TRF Special Damper with the hard black coating
Aluminum propeller joint and shafts
TT-01 Aluminum Bumper Stopper
FRP Battery Plate & Transponder Stay Set
Aluminum Motor Plate
Aluminum Motor Mount (upgrading to the Yeah Racing adjustable motor mount)
Left and right aluminum servo stays
XV-01 Universal Shaft Assembly
Aluminum Racing Steering Set and Steering Bridge
Front and Rear Carbon Damper Stays
Steel Suspension Mount Set
Front and Rear Steel Rebound Stoppers
Carbon Reinforced Hub Carriers (have held up pretty well so far)
TB Evo IV Suspension Arms
Carbon Reinforced Rear Uprights
TRF416 Front Uprights
Going to run a 64p 49T pinion with a 64p 82 spur.
I have really enjoyed tinkering with this chassis and it's been a lot of fun to drive. I personally feel this has been great for a beginning and with the hop-ups that are available it has allowed me to gradually improve my driving by slowing adding the hop-ups.
Old 07-18-2017 | 06:51 PM
  #1476
lilws6's Avatar
DSC_0194 by Don Steuck, on Flickr
DSC_0195 by Don Steuck, on Flickr
DSC_0196 by Don Steuck, on Flickr
DSC_0199 by Don Steuck, on Flickr
DSC_0203 by Don Steuck, on Flickr
DSC_0206 by Don Steuck, on Flickr
DSC_0208 by Don Steuck, on Flickr
DSC_0211 by Don Steuck, on Flickr
DSC_0213 by Don Steuck, on Flickr
DSC_0215 by Don Steuck, on Flickr
DSC_0216 by Don Steuck, on Flickr
DSC_0217 by Don Steuck, on Flickr
DSC_0218 by Don Steuck, on Flickr
Got the car together. Need to shorten and solder up some wires yet. Ride height is kind of messed up yet. Need to find new springs box kit springs are real stiff. Can't wait to get the body painted up.
JatoTheRipper and St. George like this.
lilws6 is offline
Old 07-19-2017 | 03:15 PM
  #1477
Got everything masked off this morning before work to be ready for paint when I got home. Forgot to snap a pic then.
Started playing some paint this afternoon. Fluorescent green that I'll back up with white. Also have some smoke paint for the windows.
Tail lights
nitrostarter is offline
Old 07-19-2017 | 03:59 PM
  #1478
lilws6's Avatar
I like bright green bodies 😉 Used to have an eclipse body I ran on carpet that was that color. I used tamiya smoke on my one crawler body and wasn't entirely impressed. Almost thought about getting real window tint and doing it that way. But haven't gotten that far yet in my endeavors.
lilws6 is offline
Old 07-20-2017 | 08:10 PM
  #1479
lilws6's Avatar
Got my body posts in and bumper plate. Now the body should be better secured. Also got everything wired up. Then started working on the trans am body. I got as far as getting the stripes painted. Hoping to finish it off this weekend. Still need proper vta tires.
lilws6 is offline
Old 07-21-2017 | 06:17 AM
  #1480
Laid some paint...
3 layers of green, 1 white, 1 black. Came back and sprayed Tamiya Smoke color on the windows. Also started the tedious process of cutting out decals to apply. There are many decals with yellow accents that would look great with the recommended Tamiya grey color but not so much with fluorescent green so I'll leave those off for now. Quite a few more decals to cut and apply. Still need to install the headlights, taillights, and side mirrors as well.
Old 07-21-2017 | 06:20 AM
  #1481
LJH
Upgrades/Hop-Ups:
If the track is long enough I would think you could go a bit taller with the gearing on a 25.5? I am running pretty close to the same FDR on a 17.5 and my motor temp on 90* days is right at 160.
It is great to see more TT02's taking to the track. When I bought mine I had no intention of racing it but that may happen this fall once the crazyness of summer is over and before teh ski season starts.
Cheers,
Jim
nitrostarter likes this.
LJH is offline
Old 07-21-2017 | 10:20 AM
  #1482
lilws6's Avatar
Originally Posted by nitrostarter
Laid some paint...
Looking good!!!
MajorRex likes this.
lilws6 is offline
Old 07-22-2017 | 04:31 PM
  #1483
lilws6's Avatar
Got my adjustable rear camber links made and on. Also got the body painted up looks pretty good. Just wish my stripes would have turned out a little better.
Attached Thumbnails Tamiya TT02 Thread-img_1791.jpg   Tamiya TT02 Thread-img_1799.jpg   Tamiya TT02 Thread-img_1800.jpg   Tamiya TT02 Thread-img_1803.jpg   Tamiya TT02 Thread-img_1801.jpg
lilws6 is offline
Old 07-22-2017 | 04:35 PM
  #1484
lilws6's Avatar
The rest
Attached Thumbnails Tamiya TT02 Thread-img_1793.jpg   Tamiya TT02 Thread-img_1797.jpg   Tamiya TT02 Thread-img_1798.jpg   Tamiya TT02 Thread-img_1802.jpg   Tamiya TT02 Thread-b5ef4752-267f-4ca1-9d00-e040dd7774e7.jpg
lilws6 is offline
Old 07-22-2017 | 09:41 PM
  #1485
Originally Posted by lilws6
The rest
Nice! What part did you use for the mount on the body side? I only know it's 5mm so I need something to convert it to 3mm so I can attach a ball nut.
MajorRex is offline
