Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-16-2017 | 07:52 AM
  #29251
funked1's Avatar
Originally Posted by gabc
Thanks David, I'll give this a go! Fyi, I followed Tony's recommendation to reduce rear camber, n that worked! Just that I've about -4 deg rear camber now.
Keep us posted on your progress. I have really similar problems. Weight in the rear only made it worse for me. Gonna try a ton of negative camber next.
funked1 is offline
Old 06-16-2017 | 12:00 PM
  #29252
Laguna Bozo's Avatar
Weight in the rear, even though it might seem to retard oversteer at first, really just makes the breakaway more violent and last longer. The trick when you are at this level of tuning is to lose front traction little by little, so the front doesn't dig in and throw the back around. Too stiff diffs make this difficult. Of course this is for outdoor asphalt racing, and only my $.02
OSherman and AngryRog like this.
Laguna Bozo is offline
Old 06-19-2017 | 10:04 AM
  #29253
FMW's Avatar
FMW
M-07 in action for its first run at the Tamiya track.
https://www.facebook.com/TamiyaUSA/v...type=3&theater
FMW is offline
Old 06-19-2017 | 02:30 PM
  #29254
monkeyracing's Avatar
Looks great. Still sounds like a mini. Is that one geared up with a bigger pinion?
monkeyracing is offline
Old 06-19-2017 | 03:00 PM
  #29255
gigaplex's Avatar
Reedy Mach 2 21.5, 50 degree timing, 24 tooth pinion according to one of Fred's comments on Facebook
gigaplex is offline
Old 06-19-2017 | 03:57 PM
  #29256
Default servo saver question
dumb question ,but do all three rings go in the servo saver? thanks in advance
wingnut carl is offline
Old 06-19-2017 | 04:07 PM
  #29257
k_bojar's Avatar
ok. i'm having a blonde moment, and the 'search' function and i aren't getting along too well
so.....
what happens if you use the M05v2 chassis with the v1 motor plate? is it just a matter of moving the motor 2mm more one direction?
k_bojar is offline
Old 06-19-2017 | 04:34 PM
  #29258
gigaplex's Avatar
Yes.
so.....
Yes, but also be aware that the v1 alloy motor plate will interfere with the steering rack without modification. I hear the plastic one works fine.
gigaplex is offline
Old 06-19-2017 | 04:43 PM
  #29259
M07 looking good by itself on the track.... Hopefully there will be a video of it in a race soon....
bertrandsv87 is offline
Old 06-19-2017 | 05:11 PM
  #29260
Well, if they continue to run a 24T pinion against 20T M03/5/6, of course the M07 will look good.
OVA and gigaplex like this.
Old 06-19-2017 | 06:11 PM
  #29261
Core Creations's Avatar
Exactly, I would hope it would annihilate a M05 with a 20T! It certainly looks like it handles great. Maybe it was a somewhat weak motor?!
Core Creations is offline
Old 06-19-2017 | 08:13 PM
  #29262
Where do you guys suggest to get Hop-Up parts for a MO-5V2? I am looking for a ball diff. TRF? shocks, and a few Alum. suspension bits. None of my local Hobby shops carry much in the way of Tamiya parts.
TheOtherBill is offline
Old 06-19-2017 | 09:37 PM
  #29263
AngryRog's Avatar
TQ Racing carries most everything for the M05.
TheOtherBill likes this.
AngryRog is offline
Old 06-20-2017 | 06:02 AM
  #29264
Thanks AngryRog...
Old 06-20-2017 | 06:26 AM
  #29265
speedemall's Avatar
Would anyone here have use for this body?? Tamiya Alpine A110 fits the M05RA chassis. Maybe others? 210mm short wheelbase
speedemall is offline
