Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 06-15-2017 | 02:14 PM
  #29251
Laguna Bozo's Avatar
...and have leaky shocks.
Laguna Bozo is offline
Old 06-15-2017 | 03:50 PM
  #29252
monkeyracing's Avatar
I'm using the blue o-rings right now and they're pretty good. Also have a few sets with red (rubber?) o-rings and they're fine. Been told to avoid the X versions, so I have.
As for the rcmart shipping mess, I'm guessing it's just a matter of their shipping method, mixed with customs at my end. They're not shady. I'm thinking growing pains. They've gone from a tiny company that sold fishing supplies (yes, that's weird) to a world leader in rc parts in the space of 20 years.
monkeyracing is offline
Old 06-15-2017 | 07:26 PM
  #29253
Raman's Avatar
I have placed my M05 V2 R for sale, need funds for an F1
http://www.rctech.net/forum/r-c-item...l#post14953606
Raman is offline
Old 06-16-2017 | 12:59 AM
  #29254
gabc's Avatar
Originally Posted by dmcguire
Gab,
I was having all sorts of trouble with that too at first. Biggest improvement in the car was adding weight to the back of the car. I started at 42gram in the opening under the rear shock tower. Tamed the rear and made the car way more predictable at speed.
Thanks David, I'll give this a go! Fyi, I followed Tony's recommendation to reduce rear camber, n that worked! Just that I've about -4 deg rear camber now.
gabc is offline
Old 06-16-2017 | 03:21 AM
  #29255
KA2AEV's Avatar
That sounds like a personal problem!!!
KA2AEV is offline
Old 06-16-2017 | 06:28 AM
  #29256
Shocks...not socks.
KA2AEV likes this.
Old 06-16-2017 | 07:52 AM
  #29257
funked1's Avatar
Keep us posted on your progress. I have really similar problems. Weight in the rear only made it worse for me. Gonna try a ton of negative camber next.
funked1 is offline
Old 06-16-2017 | 12:00 PM
  #29258
Weight in the rear, even though it might seem to retard oversteer at first, really just makes the breakaway more violent and last longer. The trick when you are at this level of tuning is to lose front traction little by little, so the front doesn't dig in and throw the back around. Too stiff diffs make this difficult. Of course this is for outdoor asphalt racing, and only my $.02
OSherman and AngryRog like this.
Old 06-19-2017 | 10:04 AM
  #29259
FMW's Avatar
FMW
M-07 in action for its first run at the Tamiya track.
https://www.facebook.com/TamiyaUSA/v...type=3&theater
FMW is offline
Old 06-19-2017 | 02:30 PM
  #29260
Looks great. Still sounds like a mini. Is that one geared up with a bigger pinion?
Old 06-19-2017 | 03:00 PM
  #29261
gigaplex's Avatar
Reedy Mach 2 21.5, 50 degree timing, 24 tooth pinion according to one of Fred's comments on Facebook
gigaplex is online now
Old 06-19-2017 | 03:57 PM
  #29262
Default servo saver question
dumb question ,but do all three rings go in the servo saver? thanks in advance
wingnut carl is offline
Old 06-19-2017 | 04:07 PM
  #29263
k_bojar's Avatar
ok. i'm having a blonde moment, and the 'search' function and i aren't getting along too well
so.....
what happens if you use the M05v2 chassis with the v1 motor plate? is it just a matter of moving the motor 2mm more one direction?
k_bojar is offline
Old 06-19-2017 | 04:34 PM
  #29264
gigaplex's Avatar
Yes.
so.....
Yes, but also be aware that the v1 alloy motor plate will interfere with the steering rack without modification. I hear the plastic one works fine.
Old 06-19-2017 | 04:43 PM
  #29265
M07 looking good by itself on the track.... Hopefully there will be a video of it in a race soon....
bertrandsv87 is offline
