Like Tree256Likes
Tamiya TRF419
Old 06-16-2017 | 09:39 AM
  #3406
Stein Tumert's Avatar
Originally Posted by Simmi
No they easily broke the same way
Try this one: 51293
This one?
Tamiya - 51293 F-Teile (Radträger vorn) TA05-IFS, TB-03 - Modellbau-Seidel
Stein Tumert is offline
Old 06-16-2017 | 11:56 PM
  #3407
Simmi's Avatar
Yes the black C-Hub from TA05.
Simmi is offline
Old 06-17-2017 | 02:14 AM
  #3408
How about using 54031?
Tamiya - 54031 F-Teile (Radträger) verstärkt TRF416 - Modellbau-Seidel
Old 06-17-2017 | 06:07 AM
  #3409
nubs's Avatar
Originally Posted by Stein Tumert
That's the same exact part number I just asked about.
nubs is offline
Old 06-17-2017 | 01:59 PM
  #3410
Simmi's Avatar
No, that is not the correct information.
You learn the differenz when you buy them
I drive them all time in my TRF and have no problems since i know this from a club member. Also you can see the last years since i post setup I use this C-Hub in any setup on petrirc or on my youtube post
But the front XRay works BEST!
Simmi is offline
Old 06-17-2017 | 03:13 PM
  #3411
theproffesor's Avatar
Unless you're running a TCS race, get the Exotek hub. They are great. If you are, order the hubs from the TA05.
Those two options are the way to go.
theproffesor is offline
Old 06-17-2017 | 03:31 PM
  #3412
Raman's Avatar
I'd caution against that.
The exotek hubs are great if you can gaurantee you're not going to hit anything or get hit.
I bent mine immediately because I do hit things. Tamiya sponsored driver at 702 also bent his real quick and he gets hit because of inexperienced drivers
Since I switched to the 51293 TA05 IFS standard ones, they stopped breaking. In fact Im now breaking the steering upright instead!
Also for those who switch to the IFS, I recommend the 54490 flange tube (4.5 x 3.5) for the top.. it saves you the hassle of putting in the spacer between the flange tube and steering upright.
Raman is offline
Old 06-17-2017 | 05:55 PM
  #3413
nubs's Avatar
Simmi I don't know what you are saying. I was pointing out to Stein that only a few posts prior, I asked about that exact same part number.
nubs is offline
Old 06-18-2017 | 01:04 AM
  #3414
Simmi's Avatar
Not this one:
This one
To built them look in the manual TRF 416.
Simmi is offline
Old 06-18-2017 | 12:59 PM
  #3415
No.1 at the ETS today in Stock.
Tamiya TRF419X - Christian Donath - ETS - Trencin - 16-18.06.2017
Old 06-18-2017 | 01:18 PM
  #3416
nubs's Avatar
That's great!
nubs is offline
Old 06-19-2017 | 02:48 AM
  #3417
Skiddins's Avatar
Anyone know what the progressive springs are that he used?
Mentions SMJ's
Skiddins is offline
Old 06-19-2017 | 02:59 AM
  #3418
Tom1977's Avatar
http://smj-rc.com/products-2/springs?lang=en
For 419x the short set.
Tom1977 is offline
Old 06-19-2017 | 06:01 AM
  #3419
Skiddins's Avatar
Originally Posted by Tom1977
Silver Line Springs | SMJ-RC
It mentions he used progressive SMJ's, I was wondering which progressives?
Skiddins is offline
Old 06-19-2017 | 06:03 AM
  #3420
nubs's Avatar
Most others I've seen used red. But I wouldn't​ be surprised if he was using the harder set(pink or purple) as well since he thought the Tamiya springs were too soft.
nubs is offline
