Spektrum SR2000 antenna length? >
Old 06-10-2017 | 02:29 PM
Default Spektrum SR2000 antenna length?
I bought a used SR2000 receiver, and the seller failed to mention it had no antenna. I'm looking for the length of the antenna from the outside of the case to the tip in mm. Also, I think this receiver has a single conductor antenna, and not coaxial, is that correct? Does the stock receiver have 31mm of the shield stripped off the end at the tip like the other DSMR 2.4ghz receivers?
fweasel is offline
Old 06-10-2017 | 02:45 PM
If it is a coax cable it can be any length and indeed a stripped end tip of 3.125mm
Roelof is offline
Old 06-10-2017 | 03:02 PM
there was so little of the original antenna left, it's hard to tell what type of wire it was, but does look like there was only a single solder contact on the board itself which is why I think it might be non-coaxial.
fweasel is offline
Old 06-10-2017 | 03:09 PM
Then de wire should be arround 20cm
Roelof is offline
Old 06-10-2017 | 03:24 PM
Okay, thanks, is that measured from the circuit board to tip?
fweasel is offline
Old 06-10-2017 | 04:39 PM
howardcano's Avatar
The SR2000 uses a single-conductor antenna wire (not coaxial). The length on mine is about 90mm.
howardcano is offline
Old 06-10-2017 | 04:48 PM
Beautiful, thanks. Clarification, is it 90mm from the outside edge of the case to the tip of the antenna?
fweasel is offline
Old 06-10-2017 | 05:37 PM
howardcano's Avatar
That's the full length, from the PC board.
Old 06-10-2017 | 05:54 PM
Got it. Thanks!
fweasel is offline
