Schumacher Eclipse 1/12th
#91
Just a quick thanks to those that helped with the setup advice - car went much better today, I still need to find a few tenths per lap, but it is there or thereabouts - much improved.
Now i can psuh the car rather than being very gentle with it..
Cheers.
Mark
Cheers.
Mark
#92
Has anyone noticed a "swooshing" sound coming from the car when cornering? I noticed it but ignored it but several took note of it yesterday and their assumption was that the noise was from excessive tire scrub, obviously which would affect corner speed. It has seemed to become more prevalent as the traction has increased.
#93
Has anyone found suitable sized-shims to replace the fragile static caster adjusters? Between two of us, we have broken four so far and having to buy an entire $10 part tree just to get two .5mm plastic spacers is crazy. Looks like a 2mm inner diameter x 5mm outer diamter x .5mm thick shims would be perfect.
#95
#96
They are advertised as .3mm thick. In theory I should have been able to use a combination of 5 of them to obtain the total 1.5mm thickness needed. Unfortunately when I put the calipers to them they are actually .38mm thick. I could only fit three on the upper hinge pin and as you can imagine this introduced some slop at only 1.14mm total thickness. I have a set of Xenon spacers that I believe will work. I just haven't had time to try them out as I dropped in the last set of stock Schumacher/Kawada spacers in that I had. Once those break (and they will) I will try the Xenon spacers.
#97
Found and purchased these 2mm x 5mm x .5mm thick washers: https://www.amainhobbies.com/lynx-he...-50-03/p454304
VBC Lightning 12 parts - Caster Spacer, 0.8mm D-05-VBC-0110 x 2
#98
Use 2 of these and file the arm a little.
When some time frees up I will work on a mount to fit the whole Xenon front end. Took a brief look at it earlier in the year and put it on the back burner since I couldn't see a good way to make it work without running a significantly smaller servo than what I have in the car or extending the wheelbase by moving the front axles forward.
#99
Was only my second night driving mine and loving it. So smooth and easy to drive. To go fast with my old CRC I had to push hard and take risks, this car doesn't even feel like I am trying to go fast.
Broke the lap record and destroyed the race record by over a lap in one night. Both of which I had set with the CRC.
#103
Thanks.
I was just looking at my car and remembered that some people were encountering a noise in the corner, possibly tires chattering. Could it be the slop between the bearings and the rear ride height inserts? I notice quite a bit of it and put some rubber cement on them to keep them from moving around. It was very noticeable and I wasn't comfortable running it like that since gear mesh is slightly effected.
10Likes
