Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree128Likes
Xray T4'17
Last edit by:
Print Wikipost
Old 03-04-2017 | 02:58 AM
  #931
Originally Posted by JEFFs SC10
who makes the narrow pinions? got pics?
I gotta build a new kit for outdoor action.
Does anyone use those foams in the shocks for outdoor?
Xray makes narrow pinions. I do sometimes run foam inserts on carpet and asphalt. They add "pack" which can make the car transition faster and feel more stable.
R Dodge is offline
Old 03-04-2017 | 01:54 PM
  #932
MGU's Avatar
MGU
The original x-ray ones you can buy.
MGU is offline
Old 03-04-2017 | 02:50 PM
  #933
Looking for some thoughts how to get more steering but with much less steering lock as that scrubs off way to much speed the area I'm looking at changing is the front inserts tried the usual springs,toe droop ride height diff etc.
Is there any solid info on the affects on the inserts I understand roll centre but the affects of towing the front arms out not to sure.
The car is going well and often finishes in the top 3 just need that get through the tight stuff with less lock.
Thanks for any help
Richard
tricky dickie is offline
Old 03-04-2017 | 03:03 PM
  #934
Nice
Rcforlife13 is offline
Old 03-04-2017 | 04:43 PM
  #935
miller tyme's Avatar
Thanks for any help
Richard
I like front arm sweep (rear of hingepin .5 in each side). I find it gives a little more initial turn in.
miller tyme is offline
Old 03-04-2017 | 10:12 PM
  #936
+1
pcar951 is offline
Old 03-04-2017 | 10:16 PM
  #937
Thanks for any help
Richard
Have you tried a 1.3 sway bar in front?
pcar951 is offline
Old 03-05-2017 | 03:38 AM
  #938
Sure have will give some more arm sweep, were running on asphalt fast open track but with a flip flop and that's were the issue is everywhere else the car is great.
Thanks for the suggestions
Old 03-05-2017 | 01:45 PM
  #939
Hi!
Any one can help me with set-up for carpet stock 17,5.
T4 17 build in the process
final drive ratio 5.0
Motor TrackStar 17,5
I could not find start set-up on Petit RC...
Thanks for support
Dima
dima_malyshko is offline
Old 03-05-2017 | 01:51 PM
  #940
Customworksking's Avatar
Thumbs up box
Originally Posted by dima_malyshko
Hi!
Thanks for support
Dima
box stock depending on the traction i can't tell you what to try focus on droop and roll center
Customworksking is offline
Old 03-05-2017 | 02:00 PM
  #941
TryHard's Avatar
Couple of things to try;
Less bump steer shims (1-2mm max).
Try standing the front shocks up one hole.
Try pin eccentrics of FF 0.5 down and out, FR 0.5 down.
Also try softer shock oil in the front.
Sounds like you need the car to react quicker... which the above will help with.
TryHard is offline
Old 03-05-2017 | 03:52 PM
  #942
Mfrisz's Avatar
Mfrisz is offline
Old 03-05-2017 | 11:25 PM
  #943
Hi Tryhard
Will give it a go, the track is Brendale in Queensland sure you know it.
Richard
Old 03-06-2017 | 08:01 AM
  #944
Anyone else experience the white front belt being longer/looser than the stock black belt on the 17? Two different cars from two different drivers at our local track had the same result. They didn't skip ir rub anything excessively, but was just an observation.
Tony Vega is offline
Old 03-06-2017 | 08:34 AM
  #945
Dan Hamann's Avatar
Are they experiencing the belts looser from new or after some use? I have found that the low friction belts do tend to loosen up from new more than the black belts, but they seem to hit a threshold and stay the same length after a few runs.
Dan Hamann is offline
