Team Associated RC10B64 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree710Likes
Last edit by:
Print Wikipost
Old 02-27-2017 | 12:42 AM
  #1216
Originally Posted by FLYINGBRIAN
1 of my out drives with roll pin on it will not let the gear slide all the way down.I thank that the hole for the cross pin is not drilled straight.have make a call tomorrow.
I had same issue on B44.3 outdrive. Hole for pin was drilled Off.
Pushead is offline
Old 02-27-2017 | 02:56 AM
  #1217
Originally Posted by Skeeter36
Make sure you don't have one too many shims under it. If I misunderstood your question I apologize
Have 3 washers.the 2 other different when together just fine it is just 1 out drive.
FLYINGBRIAN is offline
Old 02-27-2017 | 05:35 AM
  #1218
Originally Posted by chumlee
What front wheels are you guys using with the jconcepts 2.2 tires to get them to fit the b64d any help is appreciated
Yokomo YZ4 front wheels are perfect
John Myall likes this.
Scott R is offline
Old 02-27-2017 | 06:02 AM
  #1219
Finalist's Avatar
Has anyone driven theirs yet and can offer a good review compared to other 4wd buggies?
Mine is built, but it will be a few days before it hits the track.
How's the b64 corner and land compared to the b44.3 that chassis slapped and pushed?
Finalist is offline
Old 02-27-2017 | 06:47 AM
  #1220
JDM_DOHC_SiR's Avatar
Thumbs up
Also the ZX-6 Kyosho fronts fit perfect as well.. and AKA's site now lists them for Kyosho/B64D
Scott R likes this.
JDM_DOHC_SiR is offline
Old 02-27-2017 | 07:57 AM
  #1221
has anyone seen a custom chassis protector for the B64 yet?
Scott R is offline
Old 02-27-2017 | 08:14 AM
  #1222
IMO the two cars are not comparable. The 64 is very plush and smooth. It lands very nicely although the kit setup is too soft for my local track. I stiffened it up by going 32.5 WT and white spring.
Skeeter36 is offline
  #1223
Sweet, good to know. I figured Yokomo, and Kyosho fronts would work. I have all the tires I need now! lol
jpcopeland1 is offline
Old 02-27-2017 | 08:16 AM
  #1224
I ended up going to Grey which completely alleviated my rear "bounce issue", but my track is pretty rutted out right now. So far I love the car. Poor guy pitting next to me wasn't so lucky, he went through 2 spur gears yesterday. I didn't see anything wrong with his build, but I think something is off.
Old 02-27-2017 | 08:17 AM
  #1225
tedstryker's Avatar
Buy the Ae one cut it to your chassis
mellow likes this.
tedstryker is offline
Old 02-27-2017 | 08:27 AM
  #1226
Finished my build yesterday. Everything went fairly well.
I ended up with 1/6 diff shims, but I didn't try the 0/7. I will do that before it hits the track.
The only issue I had was I had to clearance the front chassis brace (#92039) to allow the front drive shaft to have enough movement up to install the center diff. Which is still a pain with the front steering link across that drive shaft. It's a tight fit, I almost feel like I'm going to bend a shaft. Did I miss something somewhere?
Pinebox is offline
Old 02-27-2017 | 09:57 AM
  #1227
Mine was tight as well, I just loosened the front brace a tad for some wiggle room and the diff slid right in.
Old 02-27-2017 | 10:39 AM
  #1228
Finalist's Avatar
it is a super tight install, but it wiggles in as the kit states. I had to align the dog bones and the center diff out drives at a certain rotation that allowed the center diff to slip into the center bulk head with the bones.
Finalist is offline
Old 02-27-2017 | 10:42 AM
  #1229
Finalist's Avatar
early reports are that because there is no front bumper routed under the chassis that chassis sticker/protectors are getting peeled back like crazy.
It looks like a custom sticker could be made 2-4 mm longer in the nose section. remove the front bumper and curl the sticker up towards the A brace, reattach the front bumper and go. Maybe that will solve this issue? I really don't want to run naked.
Finalist is offline
Old 02-27-2017 | 10:48 AM
  #1230
Davidka's Avatar
Why do people run chassis protectors with alloy chassis plates? I can see it with carbon/outdoors. Seems like wasted weight and inconvenience.
Davidka is offline
