Team Associated RC10B64 Thread >
Old 12-31-1969, 04:00 PM
R/C Tech Forums Expert How-Tos and Guides
Last edit by:
Print Wikipost
Like Tree710Likes
Last edit by:
Print Wikipost
Old 02-27-2017 | 11:00 AM
  #1231
Wildcat1971's Avatar
Originally Posted by Davidka
Why do people run chassis protectors with alloy chassis plates? I can see it with carbon/outdoors. Seems like wasted weight and inconvenience.
I dislike picking out my screws all the time
ZEe_NYC, mellow and Scott R like this.
Wildcat1971 is offline
Old 02-27-2017 | 11:07 AM
  #1232
Just a little FYI for building the Diffs, the hole in the outdrive for the pin under the Sun Gear is lined up with the dogbone pin slot in the outdrive. It's hard to see the hole in the diff case half
Scott R is offline
  #1233
mellow's Avatar
Originally Posted by Finalist
early reports are that because there is no front bumper routed under the chassis that chassis sticker/protectors are getting peeled back like crazy.
It looks like a custom sticker could be made 2-4 mm longer in the nose section. remove the front bumper and curl the sticker up towards the A brace, reattach the front bumper and go. Maybe that will solve this issue? I really don't want to run naked.
I bought some blank sheets with mine to make a custom one. we'll see how it goes.
mellow is offline
Old 02-27-2017 | 11:09 AM
  #1234
Cain's Avatar
Tech Legend
Originally Posted by Scott R
has anyone seen a custom chassis protector for the B64 yet?
been liking this 10 mil pvc tape someone recommended to me. can cut to suit as I want, its durable and dirt cheap.
+1 . Also, I like the chassis to look as close to new as possible for as long as possible
One thing I do miss about my old 4wd buggy was I could get to most of the settings I needed without having to pull the protector at all.
Cain is offline
Old 02-27-2017 | 11:30 AM
  #1235
Link?
Scott R is offline
Old 02-27-2017 | 11:52 AM
  #1236
I'm going to use this for my chassis protector
2 in. x 50 ft. 20 Mil Pipe Wrap Tape-53550 - The Home Depot
or
Eastman 2 in. x 100 ft. 10 Mil Black PVC Pipe-Wrap Tape-50045 - The Home Depot
Cain likes this.
Pinebox is offline
Old 02-27-2017 | 11:53 AM
  #1237
davidfast's Avatar
Link?
Google ??
ZEe_NYC and tom73 like this.
davidfast is offline
Old 02-27-2017 | 12:59 PM
  #1238
Matt Trimmings's Avatar
This is what I did and had no issues running on astro. Dirt may be a different story though.
Scott R likes this.
Matt Trimmings is offline
Old 02-27-2017 | 01:59 PM
  #1239
Finalist's Avatar
Fusion Graphics (Grapfix?) makes uncut chassis protectors in a variety of designs. They are the most durable I've tried and the adhesive lasts a long time.
Finalist is offline
  #1240
Finalist's Avatar
Hows the buggy land and corner compared to the b44.3?
Finalist is offline
Old 02-27-2017 | 02:40 PM
  #1241
I hated the last b44.3 I had. While I didn't have a good handle setup wise for the B64 yet (running on astro) I think it has a lot of potential. I need to pick up the sway bar set for the rear when it comes out to really get it better I think.
Old 02-27-2017 | 03:21 PM
  #1242
rigor's Avatar
Matt where are you running Astro?
rigor is offline
Old 02-27-2017 | 04:07 PM
  #1243
Pittster's Avatar
At our outdoor track there is enough rock's in the dirt that if you don't have a chassis protector the front bulkhead wears away in a year of racing. I use the thick jcon blank sheets and they a while I also double layer on the front bulkhead head
Pittster is offline
Old 02-27-2017 | 04:21 PM
  #1244
I had some extra automobile paint protection film kicking around, so I traced the chassis on it and made my own.
XPel and Clearbra come to mind, but you can buy the material in different thicknesses and by the foot, to make as many skins as you need.
Tobey457 is offline
Old 02-27-2017 | 04:26 PM
  #1245
mellow's Avatar
I have a couple sheets of that coming for my build. My serve, wheels, extra arms, servo horn etc showed up today, but won't have my kit until tomorrow since UPS got delayed by weather
mellow is offline
