Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree128Likes
Xray T4'17
Last edit by:
Print Wikipost
Old 02-17-2017 | 12:40 PM
  #826
Originally Posted by RevolutionM
Is everyone running diffs high or low and why?
High front to gain more steering. High at back as long as you have enough traction out of corners. If loose out, put diff rear low.
Sincerely
Marell01 is offline
Old 02-17-2017 | 01:19 PM
  #827
Lonestar's Avatar
Originally Posted by Danny-b23
On high grip we've seen a lot of guys have success with the 2.5-2.8 springs on the front with the 2.6 or 2.7 in the rear. RC we've been keeping around 0, but we're reducing toe to get the car to rotate better. I pretty much always run the carbon center brace, and just shim it up if I want a bit more flex.
Cheers - rear toe, too, obviously, can't believe I forgot that one!
So you don't tinker with RC's at all?!?
Thanks!
Paul
Lonestar is offline
Old 02-17-2017 | 11:08 PM
  #828
Thanks!
Paul
Of course you always try stuff, but that's a pretty solid starting point for high bite. You'll have to adjust camber, toe, ride height, and spacers on the camber link to get it exactly how you want it.
Danny-b23 is offline
Old 02-18-2017 | 09:31 AM
  #829
JEFFs SC10's Avatar
I ran 2.6's all around on high grip crc carpet. and it was fine. I need to see how the progressive springs work, I imagine you have more exit steering.
I was gonna try it at the Snowbirds but didn't have enough time .
JEFFs SC10 is offline
Old 02-18-2017 | 01:25 PM
  #830
Scionara05's Avatar
Anyone using a monster 21.5 or 17.5 what are you using for gearing?
96 48 with a mhp with ht rotor tep1112
Scionara05 is offline
Old 02-18-2017 | 03:59 PM
  #831
OttoKrosse's Avatar
Building a diff for the front of my t4 2017, it works so well on my t4 2015 that I want to try it on the new car. Besides the obvious weaker stock out drives what can I expect? Will the stock ones break easily and will the aluminum ones work without bending? I'm currently running the steel out drives on my 2015 but want to see if these stock ones will hold up.....your thought and opinions are welcome.
Thanks,
OttoKrosse is offline
Old 02-19-2017 | 05:45 AM
  #832
The progressive springs keep the front of the chassis from touching the track, which takes away steering. You end up with more steering all the way through the corner on the Hard Progressives.
Old 02-19-2017 | 10:03 AM
  #833
On the 21.5 or 17.5 ? What kind of temps are you running and timing? Thanks Ron
RevolutionM is offline
Old 02-20-2017 | 08:20 AM
  #834
I have a small crack in my t3 chassis that id like to maybe replace although after being shoe gooed its holding up just fine.
Does anyone have one laying around I could buy or know where i could find one thats not shipping from europe and will cost more then the car is worth? Please PM me if so, thanks.
caffeine357 is offline
Old 02-20-2017 | 08:33 AM
  #835
jakeb's Avatar
Does anyone know where I can get one of those glass plates to set the chassis on and the rod for applying pressure to the bulkheads?
jakeb is offline
Old 02-20-2017 | 08:55 AM
  #836
Pro level rc has them. Contact drew on facebook. Robbie Dodge may have one for sale at his track as well.
Chris Adams is offline
Old 02-20-2017 | 09:51 AM
  #837
Team EAM
I have some of the APEX RC ones here at home. Just shoot me a PM. Solid tempered glass and rod with a padded carrying case.
EA
EAMotorsports is offline
Old 02-20-2017 | 10:00 AM
  #838
Korey Harbke's Avatar
EA
^^^^ This. They are an awesome piece.
Korey Harbke is offline
Old 02-20-2017 | 10:56 PM
  #839
alecladanga's Avatar
Thanks,
Had the xray alu outdrives in my spool, after a year of racing (every other week, asphalt track indoor with concrete barriers), bought the steel ones since the alu will bend and the gap will widen to the point there was a noticeable play with the front tires. That's running with 17.5 blinky.
alecladanga is offline
Old 02-20-2017 | 11:34 PM
  #840
MGU's Avatar
MGU
Default Steering setup issues
I am finishing up my '2017 build and I am running into problems with the steering setup.
1.) The Steering link is hitting the topdeck. As stated in the manual I shimmed it 5mm.
2.) This is my main issue right now, I cannot get an equal throw left and right. With 100% steering I always end up with the endpoints at 85L and 95R. If I increase the throw to the left the shims hit the steering rack. Since the steering is symmetric there shouldn't be that much of a difference with the EPAs in my opinion.
MGU is offline
