Like Tree495Likes
JConcepts Thread
Old 02-02-2017 | 08:23 AM
  #9166
Understand that! Hoping the new kit releases soon
Originally Posted by PW
Not at the moment; we are waiting to see if they release a kit with a molded/production style transmission. The current LD tranny they offer is really tall and wouldn't allow room for the F2 styling in the back .
LETSDRIVE!! is offline
Old 02-05-2017 | 05:33 PM
  #9167
symmetricon's Avatar
I've done a lot of running on glued surfaces and by far the best sauce for Gold Smoothies is SXT 3.0. When starting with a brand new set, sauce for 15mins and then resauce like 3-5mins before you run. I normally only sauce 1/2 or 3/4 front tire. If you are running mod and need less/smoother steering, try a 4wd front smoothie on a 2wd front wheel. You can normally sauce less time as the tires get older/softer.
(click image for link)
I got to try this out and this combo worked exceptionally well, thanks!
symmetricon is offline
Old 02-05-2017 | 05:39 PM
  #9168
Originally Posted by LETSDRIVE!!
Hey paul. and info on if you guys are going to make a F2 body for the TLR 3.0 Laydown cars?
YZ2 will work though with the SR. Have to think it would work with the lay down
DG Designs is offline
Old 02-06-2017 | 08:24 AM
  #9169
Cain's Avatar
Got a chance to run some Jconcepts flipouts again on our carpet track due to track rules on no hardpin tires . I went with AKA red inserts, and the fronts ran the schuey staggers since they were cheap (mounted new for $10, figure why not) and it was a beautiful combo. I had the kind of planted feel I was looking for but still drivable drift.
I also tried saucing using goo gone which another driver had recommended on the forum and that really woke up the tires. Its like it conditioned the tires more than acted as a traction additive. This was less extra traction than in comparison to sxt 3.0, however, it felt a whole lot more consistent through the run.
The pins themselves on the flipouts looked to be in good condition, and I am curious to seee how the super soft compound would work relative to being a slick as others have been trying super soft compounds so they don't need as much of the SXT sauce. Since the green compound feels slightly stiffer than say prolines M4 compound, I am thining maybe these could be the hot ticket for our conditions and limitations here without lots of sauce.
Cain is offline
Old 02-07-2017 | 09:23 AM
  #9170
JoeW's Avatar
I am about to pull the trigger on a 22-4 2.0. My local track, Lake Park in Tampa, is a rough hard packed red clay with dusting on top. I am trying to find the best tires for this application.
Can you guys recommend something? I see the Dirt Maze but it only shows Rear tires?
JoeW is offline
Old 02-07-2017 | 10:19 AM
  #9171
PW's Avatar
PW
JR Mitch just TQ'd and won using a 22-4 2.0 with JConcepts Green Double Dees front and rear at Lake Park this weekend, so that would be a great start . If you want something that will last a little longer, I would recommend green Hybrid rears and green reflex fronts.
PW is offline
Old 02-07-2017 | 11:09 AM
  #9172
JoeW's Avatar
Thanks! I saw the pics on your FB site but couldn't tell which tires were on the buggies.
JoeW is offline
Old 02-07-2017 | 12:16 PM
  #9173
JoeW's Avatar
Apparently one (or both parts of these combos) are either out of stock or discontinued. Any suggestions where to buy?
JoeW is offline
Old 02-07-2017 | 12:18 PM
  #9174
Here you go!
http://www.losipartshouse.com/Search...&Submit=Search
Old 02-07-2017 | 12:50 PM
  #9175
JoeW's Avatar
Originally Posted by symmetricon
Thanks! Must be selling like hot cakes...not many left.
I'm on it!
JoeW is offline
Old 02-07-2017 | 01:00 PM
  #9176
PW's Avatar
PW
We are also scheduled to ship more to dist/dealers mid February (in the next 2 weeks) .
PW is offline
Old 02-10-2017 | 02:49 PM
  #9177
When are the 2.2 Truck Pin Downs and Swaggers going to be available to the masses?
BruceR. is offline
Old 02-11-2017 | 03:24 PM
  #9178
Question on the new JC associated B6 front ball stud mount.
Any chance that would include actual steering bellcrank posts vs using the sloppy 20mm screws?
I have always wondered why AE used screws vs posts there. I bought the Avid shoulder screws to replace the standard screws, but a new ball stud mount with posts would be the ideal solution.
Tobey457 is offline
Old 02-13-2017 | 05:15 AM
  #9179
I asked 2 weeks ago and got a vague answer about them being in Packaging and to be released soon
Scott R is offline
Old 02-13-2017 | 05:24 AM
  #9180
PW's Avatar
PW
Still don't have a firm ETA, so hoping for the end of this month.
It will use the stock mounting hardware.
PW is offline
