Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 02-01-2017 | 11:00 AM
  #2806
Originally Posted by Derrick87
Should i get a 14tooth pinion gear if im running a 1900kv?
Depending on size track, 17-19. I usually ran 18t everywhere.
ezlight is offline
Old 02-01-2017 | 11:01 AM
  #2807
Originally Posted by suzukipro
Joe will the .3 rear hubs fit on the .4 arms to allow the use of cvd's (at least in the rear)?
I would say no, the .3 CVD's just won't be long enough
ezlight is offline
Old 02-01-2017 | 11:09 AM
  #2808
jmcelroy42's Avatar
Originally Posted by Matthew_Armeni
There's only two differences between the .4 front arms and the .3 front arms, the outside uses a hingepin to retain the spindle carrier and the inside has the middle of the arm the removed to free up the suspension.
You can't use the old spindle carriers and the new front arms together since the hole sizes won't work together. The new rear arms also won't work without the new rear hubs since it's a new offset. And if you're going to run the new rear hubs you have to use the new universals. Same thing in the front, the arms, carriers, spindles, and unis all have to be used together.
If you're going to upgrade in stages you'll have to do the entire rear suspension with driveshafts, the entire front with driveshafts, the whole steering assembly, the new gearing, and the new shock parts. I think that's it .
Doesn't look like it'll work.
jmcelroy42 is offline
Old 02-01-2017 | 12:30 PM
  #2809
Derrick87's Avatar
Originally Posted by latentspeed
It is. You get quieter smoother universal driveshafts, quieter smoother ring and pinion, then there's shock cap and springs. I'm tired of saying it but steering is far better. Don't know if the wide rear hinge pin brace improves handling, but the screw that secures it now uses 2.5 driver, which eases the mind because the 2.0 screw looks as if it will strip out after going through the gearbox a few times. I see no use for the new spindle carriers. The ball bearings there only add weight and bearings can't be cleaned out from dust. The .3 is easy to clean that area and I bet the bearings don't improve performance on the. 4
Bottom line, there are updates that make the .4 worth getting. If you were to get the .3 and upgrade it to the .4 you'd be spending more money then just getting the. 4. Pay $5 for the super saver club at tower and you get several coupon codes, one if the codes gives you $75 off if you spend at least $499.
I wish I waited for the .4 instead of getting the .3 for $360. Right now .4 is $550+$5 supersaver membership-$75 off and you pay $480. Last month I think there was $90 off.
If you go with the .3 just get the updated ackerman plate, bellcrank steering and two 3x10 button head screws. Should be good enough. Maybe even as good.
Your talking tower hobbies right? There out of stock right now actually everywhere is out of stock but when they come back in im prob gonna do what you said and just get the .4 lol
Derrick87 is offline
Old 02-01-2017 | 11:06 PM
  #2810
Nice. Absolute Hobbyz has them for $550, with $55 discount, but they're out of stock too. You can also backorder it at tower and you'll get the first batch when they come in so there's no need to keep checking online to see if it's in stock. Will just deliver to you when in stock.
latentspeed is offline
Old 02-02-2017 | 04:32 AM
  #2811
jmcelroy42's Avatar
Even if though it is unconventional I ordered the F/R hubs, spindles, uni's, outer hinge pins and bearings to make it work.
So even after you get all these upgrades on your EB, you're still just going to race the SL
Old 02-02-2017 | 10:42 AM
  #2812
suzukipro's Avatar
Very likely on indoor at least, it just works better for me. To add insult to upgrade injury I just assembled the new C, D hinge pin holders and the rear gearbox won't drop in the recessed chassis area without the C plate hitting the back of the battery tray. The .4 Chassis must also be slightly longer or have things offset compared to the .3 Chassis. My $300.00 upgrade just turned into a $400.00 upgrade due to the need for a new Chassis.
Do Not Upgrade your .3 to a .4, unless of course the kits are out of stock and the parts are readily available...
suzukipro is offline
Old 02-02-2017 | 11:51 AM
  #2813
bigboyz12000's Avatar
Yeah, i was going to convert my 410.3 into an SL. I saw a thread on here about it and did the math. Made sense to just buy an SL IMO.
bigboyz12000 is offline
Old 02-02-2017 | 11:59 AM
  #2814
suzukipro's Avatar
Actually the 410.3 to SL is actually pretty affordable, you just need to get the 17mm hex adaptors, a front bumper, Buggy body and wing and you're pretty much there.
Old 02-02-2017 | 12:04 PM
  #2815
jmcelroy42's Avatar
Someone mentioned that on the .4 thread I think. You should be able to just trim away a bit of the plastic to clear the C block.
Old 02-02-2017 | 12:09 PM
  #2816
That was me and it was not needed, late night build turned me into a temporary idiot and I put the C block on backwards,,,(countersunk holes to wrong side) lol.
barbwire44 is offline
Old 02-02-2017 | 03:29 PM
  #2817
suzukipro's Avatar
I have the M2C chassis on my .3 and it isn't even close to fitting aside from the drop screw plates. I'd have to cut int the receiver box to get the C block to fit.
A new .4 Chassis has been ordered and the only thing that'll carry over from the .3 will be the differentials, and A/B hinge pin holders.
What started in theory out as good plan to only upgrade a couple items on my .3 has turned into an almost full on .4 conversion, things weren't as compatible as I thought they would be
Old 02-02-2017 | 04:56 PM
  #2818
Yup I added all the upgrades in my cart to convert the .3 to .4 and it came up to over $400. That's without the new chassis.
I'm starting to feel spoiled with the stable feel of the .4 steering. It's so good and easy to drive, its like I'm playing a video game. Think I'll be going back and forth .4 and .3 steering when I just want a different steering feel. But when it's race time the .4 steering is on for sure. With the updated steering, it drives as stable as my old kyosho fs2 but with much more steering and responsiveness. Some companies struggle to get a stable car when it steers hard, or don't have enough steering to maintain stability, but there is no compromise here. My .3 with the outdoor setup and .4 steering is super stable with a bit of rotation that is very predictable and easy to control, works in sync with the steering. The .4 has wider hinge pin braces to make it even more stable, but might be too stable with how I read at the .4 thread about someone not getting enough steering. That's just one guy though. I didn't read all the thoughts and comments there.
Old 02-02-2017 | 06:26 PM
  #2819
can you post pics of how it doesn't fit, I was thinking of trying to do the same upgrades and need to decide if its a waste of time before buying anything.
kyleman7 is offline
Old 02-02-2017 | 08:04 PM
  #2820
suzukipro's Avatar
I'll post some up when I get a chance, but the gear box won't seat into the .3 chassis due to the C hinge pin holder interfering with the back of the receiver box screw area. Also the Droop screw tabs are useless on the narrower .3 chassis with the .4 arms are to be utilized. Also in order to use the .4 arms new universals and hubs and outer hinge pins are required.
The Ackerman plate and bell cranks are a worthy upgrade, but I believe anything other add on's wouldn't be cost effective compared to just buying a new EB48.4 kit.
