Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 12-16-2016 | 05:48 AM
  #4786
Originally Posted by Skeeter36
If you bought the standard b6 buy a ball diff, keep your gull arms and tower on, and buy aluminum front pivot and 25gr C block and sway bar kit front and rear. This is if you run on a decent amount of grip clay type track
Thanks. Good to know I dont have to replace all of the parts!
denon is offline
Old 12-16-2016 | 07:39 AM
  #4787
Originally Posted by hsp-sandiego
Another fan of the Schelle Triad setup. running white inside/red/red stack. great for 17.5
I have been running 3 white on both my B5m and B6D in 17.5. What difference would I see with 1 white and 2 red. I run at a small track, So you are on the breaks, then on the power a lot. Track has high grip.
Another questions...the Centric drive pads, are they useful or needed in 17.5.
I know, I could just run the lockout, but I just could not get used to the feel of no slipper on the car.
sstretch is offline
Old 12-16-2016 | 12:02 PM
  #4788
The red pads have a little more aggressive bite - try 'em if you got 'em.
hsp-sandiego is offline
Old 12-16-2016 | 01:22 PM
  #4789
has anybody seen a setup sheet posted anywhere for spencer rivkin at the JConcepts Indoor National Series Finale
walter white is offline
Old 12-16-2016 | 03:13 PM
  #4790
B6d carpet setup go.....
sbrewer is offline
Old 12-16-2016 | 03:36 PM
  #4791
Cain's Avatar
wonder if you could just use the B6 setup as a base with the laydown tranny, appropriate springs and oils, but leave the rest as is? (flat arms, etc)
Cain is offline
Old 12-16-2016 | 04:07 PM
  #4792
gmintimidator's Avatar
Anyone using the Associated FT Wrench set? AE #1519. I'm just getting back into the sport and apparently my imperial tools are no longer needed, so I need a good quality set. If anyone can say one way or another would be appreciated. I apologize if this has been gone over, but I couldn't get it to come up.
gmintimidator is offline
Old 12-16-2016 | 04:09 PM
  #4793
Jmuck69's Avatar
Invest in some MIP wrenches. Top notch and last forever.
Jmuck69 is offline
Old 12-16-2016 | 04:26 PM
  #4794
Jmuck69 - has it right , much better product!!!
dan-o is offline
Old 12-16-2016 | 04:29 PM
  #4795
Thanks for the info. I had not seen these before. My previous ones were a set of drill blanks in Fantom handles, similar to the old Bolink Torkers set. Being that the tip is not easily replaceable, I assume these last a really long time. It looks like I may need to find a new place to keep them in my box. The handle looks fairly large. I don't see any dimensions on them. Do you have an approximation of the size?
Who do you recommend for nut drivers?
Old 12-16-2016 | 04:35 PM
  #4796
Is it cheaper to just buy a B6D as oppose to buying a bunch of parts for a B6 to make it a B6D?
Phillip F is offline
Old 12-16-2016 | 04:42 PM
  #4797
Thrifty's Avatar
Everyone seems to be turning the B6D into a B6 anyways... last to go will be the ball diff, then we can all quit asking which side the screw is supposed to be on...
Thrifty is offline
Old 12-16-2016 | 04:53 PM
  #4798
Jmuck69's Avatar
The MIP wrenches used to be the old Thorpe wrenches with translucent orange handles. MIP is going to start making nut drivers soon but I use ProTek metal handle nut drivers.
https://www.amainhobbies.com/protek-...k-8226/p212282
https://www.amainhobbies.com/protek-...k-8225/p212281
What's nice about these are you can loosen the set screw and slide the tip into the handle and shorten it. Did that on my 5.5mm.
This is good for wheel nuts
http://www.schelleracing.com/Schelle...wrench-SCH1060
Jmuck69 is offline
Old 12-16-2016 | 05:37 PM
  #4799
3n90t's Avatar
I like the feel of the handles....
I hate those typical RC tools, especially knurled aluminium handles. They hurt your hands after a while. Not only the knurled surface, but the ergonomics.
Apart from RC, I do have other hobbies that involve hand tools, fabrication of woods and metals, so MIP handles feel like real tools and feel good and secure in your hands
I'm not sure if they last forever (yet) as I've only had them for 2 years, but I've worn hex heads more than the wear (if any) on the tips.
I must admit, I've broken my 1/16" tip, maybe due to dropping it several times. But I quickly replaced it without any doubts.
I do hope they do come with nut drivers soon
3n90t is offline
Old 12-16-2016 | 05:39 PM
  #4800
https://www.amainhobbies.com/dynamit...nt2010/p413928
raved007 is offline
