Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 12-13-2016 | 10:54 AM
  #2656
Originally Posted by Matthew_Armeni
To add to this, you'll also need to trim the front of the mudguards and body for clearance as well as cut your steering turnbuckles down (remove about 2mm from both ends) or buy shorter ones from lunsford.
I didn't know about the turnbuckles. Thanks for clearing that up.
ezlight is offline
Old 12-13-2016 | 11:01 AM
  #2657
Matthew_Armeni's Avatar
Originally Posted by jmcelroy42
Can you or someone else explain what the new steering stuff is supposed to do? different geometry, what is supposed to be better about it?
It's different geometry that alters the ackermann. The best way to describe it is that it makes the steering feel smoother. It transitions better on and off power as well as beginning, middle, and end of a turn. The old geometry was pretty aggressive and once you started the turn the car could really start to come around on you. So if you had an increasing radius turn you often time would be turning too much, then counter steering to correct, then turning more to get back in line, etc. The new geometry fixes that. You can still get a lot of steering out of the car, but it is so much more usable than before. I really like the new steering setup in my SC truck, really helps calm it down.
Matthew_Armeni is offline
Old 12-13-2016 | 11:03 AM
  #2658
Interesting....
ezlight is offline
Old 12-13-2016 | 11:11 AM
  #2659
And I don't think I had to cut my turnbuckles down on my SC, I'll have to double check that though.
Old 12-13-2016 | 11:15 AM
  #2660
Ok, you'll have to cut the sc turnbuckles down as well. 3mm per side, which is what the buggy should be as well (I updated my earlier post).
Old 12-13-2016 | 11:27 AM
  #2661
mxrcracer23's Avatar
Thanks for the response, I know all the other new option parts have been very beneficial, I'll definitely give the steering components a try!
mxrcracer23 is offline
Old 12-13-2016 | 12:07 PM
  #2662
Cain's Avatar
that sounds exactly like the problem I felt on my SCT410.1 version on the larger track with its sweeper, towards the end would want to come around on you more than I liked. Indoor tight track though was fine.
Would you say the change is better all around or are there times you want the old steering setup?
Am I correct that its these turnbuckles you need to trim, the steering ones:
KR5123 has M4 threading on the ends, is 56mm long, and can be used with TKR1103 (4mm) for easy adjustability.
If so is this the lunsford option to get:
LUNS1450 4 x 50mm Titanium Turnbuckle (1/pkg)
http://www.lunsfordracing.com/mm5/me...egory_Code=4MM
Looks like associated has an option too:
https://www.amainhobbies.com/team-as...FZA2aQodQroLVA
Cain is offline
Old 12-13-2016 | 02:15 PM
  #2663
Replies in red.
Better pretty much everywhere.
TKR5123 has M4 threading on the ends, is 56mm long, and can be used with TKR1103 (4mm) for easy adjustability.
Correct.
The lunsford ones look like they have more thread so I'd prefer those, but basically any 4mm threaded 50mm long turnbuckle should work.
Old 12-13-2016 | 03:38 PM
  #2664
Cain's Avatar
good stuff thanks!
Cain is offline
Old 12-13-2016 | 07:42 PM
  #2665
So is it worth doing all these changes or just waiting on the .4?
Lately, it's been tough trying to keep up with all the changes (hrc hubs, springs, etc.) And I'm running 4 teknos. I guess it's probably only been about $120 + shipping, lol, total, but it's still extra loot. If the .4 is going to be released soon, I'm wondering if it's worth it. I guess some of that too depends on how many more changes are coming. It would be nice to know so I could decide what to do. I might change one of the buggies and see if I like the feel.
qstorm777 is offline
Old 12-13-2016 | 10:12 PM
  #2666
The separation is in the suspension front arms (Tkr5286), with the arm's support tkr5161 and tkr5162, is a lot of separation, your cars have this separation too?, is normaly?
guren is offline
Old 12-14-2016 | 01:50 AM
  #2667
Just to be clear...still using the original spindles on the 48SL and SCT410.3?
Troyster is offline
Old 12-14-2016 | 06:12 AM
  #2668
rpboggs1's Avatar
Is this a recommended update for the truggies as well?
rpboggs1 is offline
Old 12-14-2016 | 07:02 AM
  #2669
this separation iīve got en my eb48.3, i canīt upload photo
guren is offline
Old 12-14-2016 | 08:02 AM
  #2670
0verkill's Avatar
Does anyone know what body offers the most amount of room for a large battery and the most room in general?
0verkill is offline
