Kyosho Ultima SC6 Thread.......
#1636
I have one in mine, just takes the laydown gear box housings and motor plate and a few new holes in the chassis. I used my rb6.6 chassis as a template. Also i had to file my suspension block since i didn't feel like buying the new version. Only thing is that with the laydown, the side gaurds are a bit in the way when it comes to pinion and spur changes. Speaking of, I cut my side gaurds to fit a shorty sideways, i didnt mill the chassis, as i needed to add weight under the battery anyway.
#1637
My son and I have both switched over to the SC6 and love how it handles on out local indoor track. mine came with a mip ball diff and i lost the pads on the axles and destroyed a outdrive. If you have one or more new or used I am looking for one and a couple more for spares if you have stopped using them.I am hoping some one has a few in there spares and have stoped using mip. Kyosho Ultima SC/RB5/RB6 MIP/Super Diff Female Outdrive MIP12160 shoot me a pm
#1640
#1641
Some LD boxes and parts should be at my LHS by now. Now I am glad I haven’t been able to get my 6.6 built.
I may need another SC6
#1645
I have always used a ball diff in my SC6 however I am thinking about try a gear diff. Any recommendations on what weight diff oil works well for a med bite hard packed dirt/clay mix. Track is treated thus the traction is higher than one would think being it has a 80 percent dirt 20 percent clay mix.
Anyhow running mod 7.5t midship 4 gear alum idlers with Yok triple slipper. Again I really have no idea what weight diff oil to start with. Will be using PT diff oil if that matters. My attempted drive style always is to try be smooth on the throttle as trying to be aggressive with the throttle always leads to me making mistakes. Also want to try the gear diff just due to the need for rebuilding do to wear being needed far less often than a ball diff.
Any suggestion would be appreciated.
#1649
I was wondering about running the aluminum idler gears with the aluminum top shaft, does that work ok or will it destroy the top shaft? I run a gear diff and the slipper doesn't work to good with a 8.5 so I have to tighten it down and it strips the idler gears, was gonna try the avid slipper or schelle, what do you think?
#1650
Use to own a SC6 a few years back and miss it, one kit I wished I never sold. One has come up in the classifieds that I am considering getting. Is there tall about a new SC6.6 coming following the RB6/ZX6.6?
9Likes
