Kyosho Ultima SC6 Thread....... >
Like Tree9Likes
Old 11-28-2016 | 02:45 PM
  #1636
GIHOSU's Avatar
Originally Posted by bdemegs
I have one in mine, just takes the laydown gear box housings and motor plate and a few new holes in the chassis. I used my rb6.6 chassis as a template. Also i had to file my suspension block since i didn't feel like buying the new version. Only thing is that with the laydown, the side gaurds are a bit in the way when it comes to pinion and spur changes. Speaking of, I cut my side gaurds to fit a shorty sideways, i didnt mill the chassis, as i needed to add weight under the battery anyway.
3 gear or 4?
GIHOSU is offline
Old 11-28-2016 | 03:33 PM
  #1637
55Guy's Avatar
Default looking for mip outdrives
My son and I have both switched over to the SC6 and love how it handles on out local indoor track. mine came with a mip ball diff and i lost the pads on the axles and destroyed a outdrive. If you have one or more new or used I am looking for one and a couple more for spares if you have stopped using them.I am hoping some one has a few in there spares and have stoped using mip. Kyosho Ultima SC/RB5/RB6 MIP/Super Diff Female Outdrive MIP12160 shoot me a pm
55Guy is offline
Old 11-28-2016 | 04:15 PM
  #1638
Originally Posted by GIHOSU
3 gear or 4?
I went 3 gear. I was running 3 gear mid so I wanted to compare the two.
bdemegs is offline
Old 11-28-2016 | 04:26 PM
  #1639
Originally Posted by bubbaslash
Nice work. That should be a monster on carpet!
With some setup help from the guys who actually know what they are doing, the truck is now a beast. Sadly I still suck
bdemegs is offline
Old 11-28-2016 | 10:08 PM
  #1640
bubbaslash's Avatar
I feel your pain. I can't drive these things. I have my kids race them lol
bubbaslash is offline
Old 11-29-2016 | 03:54 PM
  #1641
GIHOSU's Avatar
I got mine worked out well for turf leaving the 4 gear and ball diff alone. It had some beast moments and I was happy with my results from the turf tracks up in CT with a 5th at RCHR and 4th at Hobby Hangout. What pleased me was how few changes I needed to make it work on turf. I have some ideas for my next turf setup after I switch her back to dirt duty.
Some LD boxes and parts should be at my LHS by now. Now I am glad I haven’t been able to get my 6.6 built.
I may need another SC6
GIHOSU is offline
Old 11-29-2016 | 05:54 PM
  #1642
Just did that myself. Been wanting to set it up for the looser stuff and head up your way one of these days.
bdemegs is offline
Old 12-02-2016 | 06:40 PM
  #1643
Just tossing this out there, I'm on the hunt for MIP gear diff outdrives. If anyone has a set they'd be willing to part with or knows where i can find some, kindy shoot me a PM. Thanks
bdemegs is offline
Old 12-03-2016 | 12:23 PM
  #1644
Possibly look at TSR products.
Norse is offline
Old 12-03-2016 | 12:36 PM
  #1645
I have always used a ball diff in my SC6 however I am thinking about try a gear diff. Any recommendations on what weight diff oil works well for a med bite hard packed dirt/clay mix. Track is treated thus the traction is higher than one would think being it has a 80 percent dirt 20 percent clay mix.
Anyhow running mod 7.5t midship 4 gear alum idlers with Yok triple slipper. Again I really have no idea what weight diff oil to start with. Will be using PT diff oil if that matters. My attempted drive style always is to try be smooth on the throttle as trying to be aggressive with the throttle always leads to me making mistakes. Also want to try the gear diff just due to the need for rebuilding do to wear being needed far less often than a ball diff.
Any suggestion would be appreciated.
Norse is offline
Old 12-03-2016 | 05:31 PM
  #1646
Kraig's Avatar
Super Moderator
Norse, try 2k to start.
Way back in the day, when the Kyosho SC was released as a rtr I ran associated black grease in it.
Kraig is offline
Old 12-04-2016 | 02:11 PM
  #1647
Hey Kraig,
Thank you my friend. I will definitely build the gear diff with 2k.
Thanks again for the advice
Norse is offline
Old 12-04-2016 | 02:13 PM
  #1648
Originally Posted by Norse
Hey Kraig,
Should I try the Kyosho diff grease. Not sure if the gave 2k but they may as i believe they have various weights. Or should I stick with diff oil?
Norse is offline
Old 12-12-2016 | 08:10 AM
  #1649
Originally Posted by likea45
Trans picks up dirt the same way shocks and every other moving part does on a car running on dirt. Dirt can be on the micro level and easily accumulate after a period in the trans case. It's very common.
I was wondering about running the aluminum idler gears with the aluminum top shaft, does that work ok or will it destroy the top shaft? I run a gear diff and the slipper doesn't work to good with a 8.5 so I have to tighten it down and it strips the idler gears, was gonna try the avid slipper or schelle, what do you think?
gearit is offline
Old 12-24-2016 | 01:38 PM
  #1650
Drift_Buggy's Avatar
Use to own a SC6 a few years back and miss it, one kit I wished I never sold. One has come up in the classifieds that I am considering getting. Is there tall about a new SC6.6 coming following the RB6/ZX6.6?
Drift_Buggy is offline
