Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree128Likes
Xray T4'17
Last edit by:
Print Wikipost
Old 11-12-2016 | 08:52 PM
  #481
niznai's Avatar
Originally Posted by TypeR01
Thanks it did my head in
I would shoot Xray an email especially since it seems a wide spread problem.
If that doesn't work, I would look into some shim stock. You can pick up various thickness sheets at hobby shops in Aluminium, stainless, brass, and ordinary steel. Or you could try aluminium foil from the supermarket. You can get two thickness versions: the ordinary el cheapo one and heavy duty. Cut a strip to size, make sure it fits with the bearing in and then use retaining compound like Loctite or similar to glue the foil in (not the bearing). The foil will stay there for good.
You kinda only have one shot at this, so you have to be precise and careful. I use a sacrificial bearing, superglue the shim stock to it (before cutting anything), then cut nicely with a scalpel around the bearing, leaving the strip I need attached to the outer race. Drop the bearing in with retaining compound nicely smeared around the outside of the strip (make sure the bearing support is clean), let the retaining compound go off and set, then use flashback to dissolve the superglue and take out the sacrificial bearing, clean everything, done.
But like I said, I would take it up with Xray first.
niznai is offline
Old 11-13-2016 | 07:02 AM
  #482
chiefj48's Avatar
Try using lead tape as it would be a lot easier and cleaner.
chiefj48 is offline
Old 11-13-2016 | 12:32 PM
  #483
Originally Posted by tbrymer
I think most people use .1 or .2 shims to take the play out.
That doesn't work in this case. It's actually the bearing being sloppy in the mount concentrically. It's not a thickness issue.
cplus is offline
Old 11-13-2016 | 02:23 PM
  #484
Yeah, I'll pass on introducing play into my steering rack. I'm more surprised it hasn't been fixed. These arms aren't new.
Carnage9270 is offline
Old 11-13-2016 | 04:07 PM
  #485
I chatted with hagberg about it as well.
He said he doesn't like it either, but it doesn't effect performance.
Prompted me to write to Martin Hudy about it
cplus is offline
Old 11-14-2016 | 04:19 AM
  #486
i did the mod but it is till very average
TypeR01 is offline
Old 11-14-2016 | 04:21 AM
  #487
It only seems acceptable with the kit plastic ones weird as my 16 was perfect I have ordered some A-plus ones as they seem a lot tighter i will test and let you guys know
TypeR01 is offline
Old 11-14-2016 | 10:28 AM
  #488
Can anyone recommend to me a cheap set of tires to use on asphalt? ideally on tower hobbies. I already have my spec vta tires but i dont want to tear those up as im running them on carpet only.
Thanks.
caffeine357 is offline
Old 11-14-2016 | 11:18 AM
  #489
theres some sweeps that are 28 shipped. not sure if these are my best bet though
http://www.sweepracingusa.com/10th-T...ons_p_387.html
Old 11-15-2016 | 07:29 PM
  #490
niznai's Avatar
What mod did you do?
niznai is offline
Old 11-16-2016 | 01:06 AM
  #491
Hey folks
Recently picked up a T4'17. So far the build has been amazing! Read about the steering bellcranks having a bit of slop in them - I picked up the Techra T4 steering bellcranks and they're snug around the bearings. I don't see or feel any slop in the steering system coming from the bellcranks. Might be worth checking out!
WagwanBumba is offline
Old 11-16-2016 | 08:22 AM
  #492
I see no xray set-up sheets that have a place to check as to what chassis is being used in that drivers car set-up. am I missing it? or am I just to ASSUME what chassis plate of the 3 are being used? RC America told me that all 17 cars coming into the USA are aluminum flex. As I only race my club track and it is low/medium grip asphalt, I am looking to see if anyone has been half way successful in using this chassis on asphalt before I just go spend another 100 on a graphite one.
427 COBRA is offline
Old 11-16-2016 | 08:28 AM
  #493
Skiddins's Avatar
team drivers usually say in the comments section which chassis they are using (if not the usual carbon fibre), not sure about US team drivers.
Skiddins is offline
Old 11-17-2016 | 12:19 AM
  #494
Lonestar's Avatar
Just finished mine yesterday... usual xray top-quality, everything fits nice except a couple of things
1- servo link rubs on top plate if using the servo-saver outer mid-hole... Have to use the outer side-hole to "cheat", but then throw could be an issue if not smartly thought out when you redo the whole thing
2- steering links spec in manual completely wrong. I ended up busting two ballcups as I was trying to get it as short as instructions
3- no center battery holding system, as I believe everyone's noticed by now. I ended up filing a parallelepidic plastic part that I servotaped on the chassis next to the motor mount, and voila.
Shock quality is superb, which I wasn't expecting (I remember when we used to stepchange our T1/T2/T3 performance by installing TRF shocks...)
Still, overall quality feeling is great. I miss instant belt-tension adjustment that my yokomo had, though.
Can't wait to christen it - raceday is saturday woo-hoo!
Lonestar is offline
Old 11-17-2016 | 04:38 AM
  #495
Bar
Originally Posted by WagwanBumba
Hey folks
Can you keep us guys updated how they are after some running, I looked at these myself
Bar is offline
