Tekno RC EB48.3 Thread
#2357
ahh yes he brought up a good point that I always assume everyone knows. Make sure you are setting the End Points / Travel correctly. You don't want the servo to keep trying to crank away when it's physically limited.
Watch Ryan's video here
https://www.youtube.com/watch?v=8mw4rkTeWbQ
#2359
Correct, it would drop to 208!!!! Which is an insane drop
Dimensions(mm): 40.3x20.2x37.2
Weight(g): 62.0
Speed(@4.8V sec/60): .15
Torque(@4.8V oz-in): 160.0
Speed(@6.0V sec/60): .13
Torque(@6.0V oz-in): 208.3
Speed(@7.4V sec/60): .11
Torque(@7.4V oz-in): 347.2
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
Weight(g): 62.0
Gear: Unique Steel
Bearing: 2BB
Case: Aluminum
25 Tooth Spline
#2361
We are pleased to announce a complete line of Low Frequency (LF) springs that will further improve the handling of your NB/EB48.3 vehicles. Our new spring design improves traction by reducing chassis oscillation on rough track surfaces and large jump landings. Overall stability of the vehicle is improved, providing better forward grip, increased corner speed and quicker lap times.
With additional coils as well as a larger wire diameter, the new LF springs feature a bronze gunmetal finish with a color indicator for easy spring identification. The springs fit all variants of the NB48 and EB48 vehicles and include two springs per package.
Click here for more info.
#2362
If it feels like the rear is locked down too much (not rotating), recommend adding a little camber to the rear. Should help free it to rotate in corners. The new HRC hubs do add more grip to the rear and adding camber helps it rotate and also be more forgiving in the bumps.
#2364
#2365
If the 17mm offsets to wide. It's gunna get pricey as you'll need nwmew cvd
#2366
If the 17mm offsets to wide. It's gunna get pricey as you'll need new cvd ends, and new hubs front and rear with the correct bearing size
#2367
#2368
Our rule of thumb is 300+ oz torque. the 1256 is 277oz of torque.
With that being said, it SHOULD be enough. But if you're rough on the car, landing often on one wheel, taking big tumbles, etc... you could blow through one.
The other thing is make sure your servo saver is actually working, nothing is bound. Also it's NOT an HV servo, so you can only run it at 6 volts.
This is actually the servo I had in my 10th scale stuff and 4wd sct prior to switching to the 1268.
22Likes
