    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 Yellow Low Frequency Rear Springs and TKR8762 Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 Orange Low Frequency Rear Springs and TKR8763 Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 Hinge Pins (inner, front/rear)
TKR6061T Rear Shock Shafts w/ TiNi Coating and TKR6017T Front Shock Shafts w/ TiNi Coating
TKR5286 Front Suspension Arms and TKR5184 Rear Suspension Arms
TKR5194 Spindle Carriers
TKR6009 Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Like Tree13Likes
Old 12-07-2015, 07:19 AM   #856
wittyname's Avatar
Originally Posted by R1Joel View Post
Just wondering what pinions you guys use? I ordered a 19t for mine with an 1800kv motor. Worried it might be a bit much. Large tracks
I use a 19 on a 1900 . 150ft straight and I run out of steam with about 30 feet or so left .
No heat issues what so ever ...
Josh W.
Don't forget ... Have fun , talk sh*$ with your buddies, and have fun.
I race so I can have people flip my car over ....
wittyname is offline   Reply With Quote
Old 12-07-2015, 04:21 PM   #857
R1Joel's Avatar
Originally Posted by Mav-07 View Post
Welcome to the team my friend :-)
Glad to become a part of it.
Great, thankyou for the info.
R1Joel is offline   Reply With Quote
Old 12-07-2015, 09:20 PM   #858
jason07's Avatar
I bought the Tekno servo horn TKR 5252 (24T) and I have a HiTec 7950 servo, is this the right horn? It seems awfully hard to push on and off.
Agama A215E Hobbywing 1900KV and Xerun XR8
Agama A215 Bullitt B221
jason07 is offline   Reply With Quote
Old 12-07-2015, 11:00 PM   #859
lala4fire's Avatar
Yes,that's the one. Is the little screw that clamps the horn to the spline loosened?
Associated FT SC10.2 SCB/ tekin rs/gen2 10.5
Associated B6/ tekin rs 2/gen3 8.5 B5 rear motor
Tekno EB48.4/tekin rx8 2/gen2 1900kv
Tekno NB48.4/ Alpha Dragon III
lala4fire is offline   Reply With Quote
Old 12-08-2015, 04:40 PM   #860
R1Joel's Avatar
It's here. Build time.
Old 12-08-2015, 06:07 PM   #861
werner sline's Avatar
i don't own a eb48 but I was always fan of its design
good driving there : https://www.youtube.com/watch?v=5XZVyNaD_gs
i checked the user manual and like that put the new tapered shaft
what about CVD's front ? can they handle full steering like universal joints ?
werner sline is offline   Reply With Quote
Old 12-08-2015, 06:18 PM   #862
RokleM's Avatar
Trader Rating: 33 (100%+)
There is so much steering on Tekno vehicles, we typically use/recommend limiters.
Originally Posted by teknorc View Post
That's correct. And yes we know people like lots of steering. Our pro drivers tell us this all the time . Something to keep in mind though about steering...
The design of the EB/NB line of vehicles has more steering throw than any other vehicle on the market. Probably by a good 5 or more degrees. At first we thought this was a huge advantage. Lately, through constant testing, we have found the cars are faster and waaaaay more consistent with less steering throw.
So if you're not using the built in steering stops, you're doing yourself a huge disservice. We are using 4 steering limiter washers on the EB/NB and the results have been awesome. Yes, the turning radius is reduced, but lap times and consistency have proven this is a non-factor.
Here's what goes wrong with too much steering throw:
Rear end washes out when landing jumps
Rear end continues to come around exiting corners
Feels like you are struggling for traction at times
Bump handling is unpredictable
Initial steering is extremely twitchy
And other issues to be sure
Here's what's going on. The last 5+ degrees of steering throw happen very quickly and the servo has very very little leverage on the wheels at full throw. This causes the inside wheel to act erratically and get tossed left/right at the whims of the track surface. Without a positive stop there, the inside wheel is going crazy and causing inconsistencies with the handling. The CV's can accommodate this extreme working angle, but there is more chatter which creates further issues.
Even if you just limit your EPA, the inside wheel is still free to move too far when the conditions arise. So install the washers first, then reset your EPA to match.
There are literally dozens of other adjustments that will result in more steering if desired (shocks, springs, ride height, sway bars, diffs, camber links, toe, etc.). By first limiting the throw, you can focus on creating more 'setup steering'. Think of setup steering as being more consistent vs. mechanical steering (i.e. throw).
Additionally, you won't be fighting the car so you will be spending less time tuning something bad out and more time tuning good stuff in.
- Eric G. -
Tekno EB48.4, NB48.4, ET48.3, NT48.3, EB410
Sponsored by: TeknoRC, REDS Racing USA, Pro-Line Racing, Agency-Z, Krawl Off-Road
RokleM is offline   Reply With Quote
Old 12-08-2015, 06:29 PM   #863
Enjoy, I know I sure did. This kit has just about the best fit and finish on anything I have built going back four decades.
Fasttrak is offline   Reply With Quote
Old 12-08-2015, 07:54 PM   #864
thanks for the complete answer, I got all need to know now !
Old 12-09-2015, 01:27 AM   #865
R1Joel's Avatar
Build is going fairly smooth so far. I am enjoying it. Up to building rear driveshafts. Not to bad for my first build.
Old 12-09-2015, 05:17 PM   #866
Nice! I did mine with a sprained thumb so it wasnt much fun, so I took the hex tips out of my drivers and put them into my cordless drill, if you can do so it saves a grip of time mate!
JOELD is offline   Reply With Quote
Old 12-09-2015, 07:00 PM   #867
R1Joel's Avatar
I'm starting to wish I had an electric driver. I have a sore wrist and a bad blister on one of my fingers. Enjoying it though.
Old 12-09-2015, 07:27 PM   #868
mkl
I especially like my driver with those long screws that hold the suspension blocks on. A driver comes in very handy with those.
Glad you are enjoying the build. You'll like it even better when you drive it
Tekno SCT410, Tekno EB48, Tekno ET48, X-Ray 808E, TRCE Slash 4x4, Tamiya Lunchbox, Tamiya Frog, Slash 4x4, Axial Wraith
mkl is offline   Reply With Quote
Old 12-09-2015, 08:47 PM   #869
Originally Posted by doctorfeelgood5 View Post
does everyone think that it is worth upgrading an .2 to the .3 with an upgrade kit?
It's always fun to have the newest and the best but I seriously doubt that if you had both the .2 and the .3 set up exactly and ran them back-to-back it would buy you any lower track times. My experiences so far running the 1/8th scale buggy against guys who are running chassis going back two and three generations of Mugen, Tekno and a few others is this, the fast guys are very good at chassis setup and are very good consistent drivers. If I was you I would not waste my money, I would buy more tires and batteries and spend more time perfecting your chassis setup and your driving skills.
Old 12-09-2015, 09:36 PM   #870
R1Joel's Avatar
Enjoying everything except the rod ends. They will be the death of me.
