Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 10-19-2016 | 03:25 AM
  #3871
sport10's Avatar
Originally Posted by Balony
Using the short eyelet on the front keeps the droop the same as a long eyelet on the rear due to the front is raised due to the anti squat that is built in to the rear mount.
Thanks, makes since now.
sport10 is offline
Old 10-19-2016 | 04:26 AM
  #3872
Originally Posted by TonyCooperUK
I have a B5m thats fully tricked up, not really worth anything here in UK, I know that the schelle rear hubs will fit but I lose axle height adjustment
also looking at it I have ally rear wing mounts, but they would move the wing 10mm forwards,
is this likely to be an issue?
just trying to save parts from waste on the B5m and upgrade the B6 without spending a fortune again LOL
I'm pretty sure I read on Schelle's website that their rear hubs for b5 and B6d are the same part #. B6 however has a different hub part # from Schelle.
RookieRacer00 is offline
Old 10-19-2016 | 07:46 AM
  #3873
anyone see the photo of Rivkin's B6 on JConcepts Facebook Page?
That front tower is thick as hell
Scott R is offline
Old 10-19-2016 | 08:48 AM
  #3874
Wildcat1971's Avatar
Tech Prophet
it looks normal to me.....
Wildcat1971 is offline
Old 10-19-2016 | 09:05 AM
  #3875
Not to me
Scott R is offline
Old 10-19-2016 | 09:15 AM
  #3876
Not to me
Looks like my stock one.
Tijuana_Taxi is offline
Old 10-19-2016 | 10:39 AM
  #3877
+1 for stock
Uhudler is offline
Old 10-19-2016 | 11:06 AM
  #3878
SMcD's Avatar
sport10 and Balony, thanks!
I ran some practice laps yesterday. Basically, after practicing, I switched to the short eyelet. The dogbone pin is just so close to the end of the outdrive at full droop that in the right crash event, the bone may pop out causing DNF. I also suspect that the piston is better placed in the shock fluid column with the short eyelet at the front of the arm.
I am not super fast, but I love the way the car handles in this configuration. Just gobs and gobs of steering, carries so much corner speed, jumps flat
SMcD is offline
Old 10-19-2016 | 11:25 AM
  #3879
Silverstonev8's Avatar
Are you running the cva shims 91605?
Silverstonev8 is offline
Old 10-19-2016 | 03:09 PM
  #3880
SMcD's Avatar
No, but I can see how they may also help keep the bone in the outdrive. In the end, I followed Kody's recommendation and overall droop is reduced enough to keep things in check
EDIT: actually, I'm not sure this is true. the back end of my car is apart right now. I will take a real close look at things when I get it back together. thinking about it now without the car in front of me, I think the biggest effect is the tension on the shock spring as the eyelet "looses" length at the shaft/spring retainer (threads are showing now) and not the bottom. this will mean I have to change the shock collar setting to maintain ride height. uuuggghhh confusion...
SMcD is offline
Old 10-19-2016 | 04:38 PM
  #3881
tony montana's Avatar
Sean you running laydown?
tony montana is online now
Old 10-19-2016 | 07:58 PM
  #3882
SMcD's Avatar
Yeah. After looking at Hunter`s buggy, I went all in.
SMcD is offline
Old 10-19-2016 | 08:12 PM
  #3883
RCBuddha's Avatar
http://www.redrc.net/2016/10/rdrp-b6...hinge-pin-set/
RCBuddha is offline
Old 10-19-2016 | 11:38 PM
  #3884
ChadB.'s Avatar
Which car does most people use for both Mod and Stock? I am contemplating on getting a buggy to play with for the winter.
ChadB. is offline
Old 10-20-2016 | 04:27 AM
  #3885
Do the new style ballcups need to be squeezed like the old ones and are the new ones compatible with the 5 platform?
