Like Tree1Likes
Dynamite Mach 2 .21
Old 08-26-2013 | 11:12 AM
  #241
I am sure i could lean out the hsn for better performance but it seems to me that this would only increase heat. Also, with the lsn set at 4 turns out, I am unable to lean it out as my idle goes to high. Would that be an air leak problem or possibly a bad setting on my idle screw?
BTW, I have the same pipe also. So far I am only on the 10th/11th-ish tank
jc338 is offline
Old 08-26-2013 | 02:01 PM
  #242
set idle gap at .5 to .7 mm.
reset needles back to factory settings
change fuel line & check all gaskets.. check gas tank for leaks
seal back plate & carb with high temp rv
then start tuning from there..
if u still get high temps after you do all that, then your gonna have to take engine apart to inspect.
could be a leaky front bearing also..
tate13 is offline
Old 08-27-2013 | 01:04 PM
  #243
Thanks....Does idle gap need to be set with the carb. re-stricter removed?
Also, did you try any of the other re-stricers, or without one in, what results did you get?
jc338 is offline
Old 08-27-2013 | 01:24 PM
  #244
I set my idle gap with carb restricter installed, im guessing u could do it with it out to get it more precise..
It came with a 8.5 stock i took it out and used the 7.5 for more runtime . It also comes with a 8.0.
U need the restricter in, without it runtimes will be horrible.
I was barely gettin 6 mins with the 8.5 so i changed it to the 7.5
tate13 is offline
Old 09-09-2013 | 04:48 PM
  #245
SamuraiJack's Avatar
Originally Posted by pascalfd
Ok, so the manual is definitely wrong claiming LSN 2 turn out. Needs to be at least 4 out - just like out of the box setting.
Just wanted to add this is my experience too. LSN at 2 is impossible. Did they perhaps change this in more recent versions?
Can anyone else speak to the LSN: how it came out of the box and what works for ya?
SamuraiJack is offline
Old 11-09-2013 | 01:35 PM
  #246
Just bumping this question.
Also, are temps typically hotter with turbo button/plugs?
Old 11-18-2013 | 06:50 AM
  #247
Default High Idle / take offs
(I may be the only one who cares about this engine anymore, but I'll give it one more whirl, may be a general engine issue this folks can help with.)
I may be having same old issue of too rich LSN and too wide idle gap, however I have tried avoiding it, got the gap quite small. But I still get what I believe is referred to "runaway", or high idle that does not want to settle. Not on the bench, but after laps.
What happens for me is I tune the engine warmed up on the bench (140-220 degrees) but after running some high speed laps on the track my engine likes to take off on its own after I let off the throttle, and then when I bring it in it doesnt go back down to idle and I have to kill it. I assured the carb is closing properly (spring). I have a few more things to do verify air leaks/proper seals tho. Is it possible that as the engine gets real hot air leaks present themselves? I had to zip tie fuel lines because as they got hot they lost seal. I wonder if air is getting into the engine somewhere.
Old 12-02-2013 | 07:54 AM
  #248
Heard from Horizon Support that factory setting is 2.5 turns out for LSN.... fwiw
Old 10-10-2016 | 07:21 PM
  #249
1/8 IC Fan's Avatar
Thanks for the info, your not the only one. I ran their other motors (.21s) years ago, just came across a new Mach 2 to try out in my old buggy, for friends and family to try.
1/8 IC Fan is offline
