Dynamite Mach 2 .21
#91
i was planning on putting one of these on my slayer. What clutch/pipe would you recommend me getting. I was thinking a losi 8ight clutch/flywheel and a dynamite 053 pipe. Would that setup work ok??
#92
isn't this too much motor for a slayer? those things have narrow tires. you might have all sorts of traction issues.
#94
You can go on losi.com and look at the parts for the 350 and see at least a partial view of the sleeve. It looks like it probably is only a 3 port. But it would be awesome if someone would post up pictures of one so we could know for sure.
#95
#96
I must say I'm pretty impressed with this engine. I finally got to race it this last weekend and even with the temperature dropping 15+ degrees during the racing and causing it to run lean, I still didn't have any trouble with it running bad or flaming out. I was actually still running the glowplug that came in it (Dynamite #5) up until right before the mains. I only put a new one in it just to be safe. The old one still looks good, so I will probably put it back in for practice. The engine isn't ballistic, but it makes pretty good power from bottom to top. I was running a three shoe clutch with 1.1mm springs, but I think it should pull 1.0mm springs no problem (I like a lot of snap). I think if anyone out there is looking for a good backup/club race engine, this thing is perfect
I paired mine up with a Dynamite 053, and I couldn't be happier with an engine/pipe combo that is less than $175.
#97
I know the Dynamite motors of the past like to be ran a little hot. What temps are you guys running these? A guy I know was racing his and it was kinda slow. It was running about 210 degress. I think he needs to lean it out more.
#99
I've been breaking mine in a tank or two at a time as I would get a chance to over the last couple of weeks since I bought it. I've run about a Liter of fuel through it. Last night I ran it on a track for the first time and I have to say that I was pleasantly surprised. It's still rich on the bottom but it seemed plenty fast once it would clean out. I think this is gonna make a pretty decent practice/club race type engine.
Mine is paired with a DYN053 pipe, like the previous poster said it makes a nice combo for under $200. The only question now is how long will it last? I'll probably swap the rod out after a gallon or so and then we'll see how long she goes.
#100
Mine was a bit on the lean side after the weather changed and it cooled off and it was running around 270*. I think it will probably run around 240* tuned right, but I'm not going to tune mine for temp. At home running it in my yard I could make it scream only running 220-230*. I did notice that mine doesn't like to be very lean on the bottom, if I try to tune it as the manual suggests (pinch test), it lean bogs and loses bottom end. If I keep it on the rich side, it runs great.
#101
I have 2 race weekends on mine so far and its getting better every time out, I took the OS 2060 off and put on a new Dynamite 053, will race it tonite and report back. I also have a nice used .21 XP i picked up from a race buddy, I'm gonna see how it does in my truggy....
#103
This helps too...............107.99
#6588 of 6591 by Kendall Bennett ~ A Main Hobbies (kendallb) on Fri Jul 3 11:13:08 2009:
Newsletter went out last night. New codes are:
If Your Order Totals: You Save! Refer to Coupon#
$100.00 - $149.99 $5.00 DPPAN95
$150.00 - $249.99 $12.50 DPPAN912
$250 or more $25.00 DPPAN925
1Likes
