Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 10-08-2016 | 04:39 AM
  #28201
marcos graveyar's Avatar
Originally Posted by SUNA
Thanks Marcos. Looks like it is hard to get...and it appears to be quite $$.
Kamtec in the UK do a cheap lexan version as well as an ABS version.
http://www.kamtec.co.uk/epages/BT464...Products/K0050
Can't vouch for fit or finesse, but definitely cheap.
marcos graveyar is offline
Old 10-08-2016 | 04:46 AM
  #28202
Also check out teambluegroove on ebay, they do a few Golf shells.
Old 10-08-2016 | 06:53 PM
  #28203
I have a M05v2 upgraded chassis; I recently found out that I needed the 1.6mm spacer for my diff of which I didn't have before.
Problem is; When I put the spacer in as per directons; the diff binds. My only assumption is the motor plate I am using is still the older M05 motor plate; not the V2.
Since it clearly fits; should I bother to get another motor plate?
Thanks Big Dee for the shims; I'll return them if I don't need to get another motor plate.
irvinew is offline
Old 10-09-2016 | 02:22 AM
  #28204
The M05 motor plate and the M05 VerII motor plate are different offsets.
You need to use the VerII plate with the VerII chassis.
Old 10-09-2016 | 04:39 PM
  #28205
mcmattila's Avatar
Today I used some wire to stitch up the front of my Mini. I have no idea if/for how long this will hold up, but I sure do like the look!
Attached Thumbnails Tamiya mini cooper-mini_kenwood_11.jpg   Tamiya mini cooper-mini_kenwood_13.jpg
mcmattila is offline
Old 10-09-2016 | 04:54 PM
  #28206
gigaplex's Avatar
I feel like it wasn't that long ago that we saw that shell in pristine condition
gigaplex is offline
Old 10-10-2016 | 01:39 AM
  #28207
mcmattila's Avatar
Nahh..! That was like.. over.. a month ago. Man, it has really taken some beating But, this is my first car and I guess it's to be expected. And I've got two other bodies waiting to get painted!
I think the hardest hits came just a week ago (not counting a couple of spectacular jumps out of the raceway), when I installed a differential stiffing kit, and I just couldn't control the car. It turned out it was mostly the controller settings that were making my driving so twitchy, and yesterday after a friend adjusted some settings, I was really able to keep up with the big boys. Even shaved almost a second off my previous PB lap time that was done with the default open diff! Still, got a lot to improve on my driving lines..
Old 10-10-2016 | 05:07 AM
  #28208
KA2AEV's Avatar
You should paint a mouth someplace on the front grill, oh man, Frankenmini!!!
Cool!
KA2AEV is offline
Old 10-10-2016 | 07:42 AM
  #28209
c-lyon's Avatar
If you also coat the damaged area with ShoeGoo it should last a bit longer.
c-lyon is offline
Old 10-10-2016 | 11:08 AM
  #28210
monkeyracing's Avatar
Gorilla Clear Repair tape! Clean the surface to be repaired with alcohol/brake cleaner/monkey spit first. Apply the tape to the flattest area first. Heat with a blow dryer or heat gun and mash it down into the curved areas. You might have to do a relief cut if it gets to a point where it's going to bunch up.
The stuff is strong as hell, flexes and sticks like there's no tomorrow.
monkeyracing is offline
Old 10-10-2016 | 12:55 PM
  #28211
mcmattila's Avatar
Thanks for all the suggestions guys! I'll see how I'll go about patching it further if/when it disintegrates any further. Currently there's some tape used to patch steam pipes behind the cracks, and it seems to stick nicely. The application wasn't the best though, so the stitches have some actual function in addition to good looks!
I don't know if we have Shoe Goo or anything similar where I live, but I do know that we have Gorilla tapes. I have a roll of the basic black one myself, and have been really happy with it.
Old 10-10-2016 | 01:02 PM
  #28212
MD's Avatar
MD
I use Goop. There is household and automotive versions. It's similar to Shoe Goo. You can get it at a hardware store.
MD is offline
Old 10-15-2016 | 05:01 AM
  #28213
gigaplex's Avatar
So I've just been watching a build log of the Monte Carlo Mini M05 kit, and noticed that he had a serious issue where the body didn't actually fit on the chassis. It looks like the rear portion of the chassis has the version 2 droop brace added, even though it's a version 1 kit. Has anyone else noticed this kind of problem before?
Skip to the 16 minute mark if the link doesn't take you there directly.
https://www.youtube.com/watch?v=7SM4ELMYpUQ&t=16m00s
gigaplex is offline
Old 10-15-2016 | 07:43 AM
  #28214
That's a v2 chassis for sure. The v2 doesn't come as anything other than a rolling chassis or as a spare part. Maybe the builder got it second hand or bought the v2 chassis without realising this limitation.
Mini35 is offline
Old 10-15-2016 | 07:45 AM
  #28215
As said you definitely do need the v2 plate on a v2 or it doesn't offset the intermediate gear properly.
Mini35 is offline
