Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree128Likes
Xray T4'17
Last edit by:
Print Wikipost
Old 10-01-2016 | 05:05 AM
  #226
TryHard's Avatar
Originally Posted by theproffesor
Glad to see you immediately assume every new feature is an X-ray first feature. Could it possibly be that X-ray copied from VBC?
Given the feature has been on the team cars for quite a while (at least the last few ETS races).. nup. Just because VBC released the CAD images doesnt mean they had the idea first (plus speaking to lucas at the world's, they had only just started to play around with it).
Regardless... i would say the inspiration is actually more awesomatix than anything else..
TryHard is offline
Old 10-01-2016 | 07:14 AM
  #227
syndr0me's Avatar
Been a lot of that going on lately.
syndr0me is offline
Old 10-01-2016 | 07:34 AM
  #228
Originally Posted by silden
It stiffens the cassis in the center position, probably like the upper deck.
The servo and the motor mount are the best way to connect the front and back of the car in the centerline that low in the chassis.
Oh I see what you are saying, the chassis is stiffer torsionally by having more screws or vice versa. I was thinking the motor mount was a floating one and needed bracing front to rear.
Originally Posted by B00t13g
Lots of options.
*snip*
Thank you both, seems similar to what the AE TC4FT had. Not surprised to see ways to limit flex in the current cars.
30Tooth is offline
Old 10-01-2016 | 08:17 PM
  #229
niznai's Avatar
I wonder why they kept the battery slot cuts in the chassis if they're pursuing absolute symmetry in chassis flex.
niznai is offline
Old 10-01-2016 | 09:45 PM
  #230
It is an oddity Xray are sticking with under and over tape.
So easy to copy one of the current solutions from the others.
Don't expect there is much in that though. Flex at the extremity of the chassis wouldn't be as important as the flex down the centre.
cplus is offline
Old 10-02-2016 | 06:05 AM
  #231
blarks's Avatar
blarks is offline
Old 10-02-2016 | 06:11 AM
  #232
Originally Posted by blarks
I heard the translator budget was cutted for this year's release.
30Tooth is offline
Old 10-02-2016 | 06:12 AM
  #233
Set
Set is offline
Old 10-02-2016 | 09:51 AM
  #234
, okay I'm out.
30Tooth is offline
Old 10-02-2016 | 12:03 PM
  #235
BNT
Does anyone know yet if the body posts are at the same location on the 17 car as with the 16 car?
BNT is offline
Old 10-02-2016 | 01:13 PM
  #236
Yes they are.
I ran my car for the first time today. Car was out of the box just as fast as my year old 16. I'm pretty pumped to go even faster this coming year.
Chris Adams is offline
Old 10-02-2016 | 09:55 PM
  #237
wkderf's Avatar
anyone know who has these in stock in the US?
wkderf is offline
Old 10-02-2016 | 11:05 PM
  #238
Johnny Wishbone's Avatar
SpecR did it a few years ago.
Johnny Wishbone is offline
Old 10-03-2016 | 02:12 AM
  #239
BNT
Originally Posted by Chris Adams
Yes they are.
Great Thanks
Its always easier convincing the misses when you can recycle the bodies...
BNT is offline
Old 10-03-2016 | 03:56 AM
  #240
niznai's Avatar
Say what?!
Flex is impacted by the chassis width. Cutting those slots basically takes anything from the slot inner end out of the flex equation.
You can still use tape without slots. I do.
I just found it strange they go to the trouble of milling the motor cut out on the opposite side, but leave the battery slots as they are.
niznai is offline
