Tekno RC EB48.3 Thread
#2192
http://www.fiercercsolutions.com/Tek...kit-FRC010.htm
or other upgrade kits from them... and piece together what you need..you are best off buying a used eb48.3 though imo.. since it comes with all the aluminum upgrades you would need to buy.
#2195
They share a ton of parts, but when you build the eb itself you'll see all of the upgrades it comes with.. you can get a used one for $300-330 here easily, probably cheaper.
Did you see the other link I posted for you?
I recommend just getting both. [:
#2196
Beginner here... building this as my first kit.
Question... when I'm putting together the front gearbox, it says it should spin freely with no grinding or crunching.
Mine spins "pretty freely" with no binding at all, but there's definitely some grinding sound. No matter how I place the shims there's still some grinding.
Should this be smooth like butter, or is some grinding ok?
Not sure if I need more shims or if I screwed up something else.
Thanks for the help guys.
#2198
When I build my diffs, I place the diff assembly (no grease on ring gear) in the diff housing half with the pinion. I hold the ring gear in place so it doesn't move and rock the pinion back and forth reshimming until I get just a little tick like meshing a spur gear. Then I make sure I turns freely, grease the ring gear and close up the diff assembly. U will probably want to revisit the shimming and diff oil after running several packs thru it as the gears wear in.
#2199
Thanks guys (deceit, qstorm777) for the advice. I appreciate it. You'll probably be hearing more from me.
I feel like the instructions are very clear if you've built another kit before. But as a beginner there's some things I'm having to learn by watching YouTube and reading everything on here.
#2200
Ryan Lutz diff building tips
#2201
#2202
https://www.youtube.com/user/justpoet/videos
He has a few video's on tips and trick for building an ET48.3....Which most if not all the tips will cross over.
Ryan lutz & TeknoRC has also released a few tips video's.
#2204
I did watch some of the ET48.3 videos, but I was completely unaware of the Tekno ones with Lutz. They never came up in my search. I guess because I was looking specifically for EB48.3.
I'll have to check those out now before I go any further.
I already know I didn't use enough grease on the outdrives, so I'll probably end up rebuilding the diff's once I put it all together and make sure all the parts are ok.
#2205
I hate that they give you such a small tube of grease.. When I was building both my SCT and EB I didn't use much because I couldn't tell how much I had to save for later in the build. I just now bought a huge tub of grease and redid all my diffs and cleaned/regreased the whole car. Never again will I have little grease where its needed lol.
22Likes
