Xray X1 - Formula One Car >
Like Tree366Likes
Old 08-10-2016 | 07:18 PM
  #1591
F N CUDA's Avatar
Originally Posted by lagcisco
Is this the harder F60 kit tire you guys are referring to?
http://www3.towerhobbies.com/cgi-bin...&I=LXYJA3&P=PU
Yes 51399 is the "Kit" tire that works
http://www.tqrcracing.com/shop/produ...w.asp?p_id=580
Be careful because 54198 is the "Optional Hard" kit style tire that they made before there was a good rear tire offered.
I have used these in extreme cases with some success when nothing seemed to work.
And stay away from the 54199 "Optional Soft" rear offered by Tamiya back in the day as they are junk but they were trying.
F N CUDA is offline
Old 08-10-2016 | 07:39 PM
  #1592
Thanks for the info guys, that will help me buy some more sets.
Scott_T is offline
Old 08-10-2016 | 07:50 PM
  #1593
NutDriver's Avatar
I believe that the CRC F1 tires are very close to the TCS tires. Cheaper, too.
NutDriver is offline
Old 08-11-2016 | 06:23 AM
  #1594
Picked up a x1 15 yesterday. What are the best parts to keep on hand?
micrors4guy is offline
Old 08-11-2016 | 07:09 AM
  #1595
Dan's Avatar
Dan
Spur, rear axle bearings, and if you have hard boards, an upper and lower arm. Oh, don't forget various shims and the suspension O rings.
Dan is offline
Old 08-11-2016 | 12:17 PM
  #1596
robk's Avatar
same tire, different logo......
robk is offline
Old 08-11-2016 | 04:13 PM
  #1597
JayL's Avatar
Originally Posted by racenut123
People refused to believe I use the Pit Shimizu 574/575 combo on a high traction/High speed track with a track temp of 154 F.
That's because you are always trying to trick us! hehe
574/575 have a MUCH wider range than anyone believes.
JayL is offline
Old 08-11-2016 | 06:24 PM
  #1598
Didn't you hear? I am a Magician.
I ran the 574/575 at the clubrace before the CTS Finale. After, I decided to go 71/72 because I didn't want to mount any new tires for outdoors and decided to try the premounts. Well you know how that ended. I used my older carpet 71/72 sets that ran just fine.
racenut123 is offline
Old 08-12-2016 | 09:32 AM
  #1599
JayL's Avatar
you are literally a magician
Stupid rear premounts I blew out two sets as well
how is everyone taping the rear pit insert?
What tape?
tape on tire side?
tape on rim side?
or foam glue?
JayL is offline
Old 08-12-2016 | 10:53 AM
  #1600
shortcut's Avatar
What tape?
tape on tire side?
tape on rim side?
or foam glue?
I used rubber cement from a bicycle tire repair kit and it worked fine.
shortcut is offline
Old 08-12-2016 | 11:16 AM
  #1601
NutDriver's Avatar
Jay,
Are you talking about gluing the strip to itself to make it a loop, gluing the loop to the wheel, or gluing the loop to the tire?
I glue the strip together to make a loop using 3M spray adhesive. Spray each end, wait 3-5 minutes, then press together. Scirocco14 shared this with me.
Old 08-12-2016 | 11:33 AM
  #1602
What tape?
tape on tire side?
tape on rim side?
or foam glue?
I use Elmer's rubber cement. Apply to both side, let dry to tacky, then press together. No hard seam and the glue stays flexible.
chensleyrc1 is online now
Old 08-12-2016 | 12:23 PM
  #1603
Dan's Avatar
Dan
Elmers rubber cement and a strip of clear packing tape on both sides. Never any splits or issues doing it this way for a few years.
Dan is offline
Old 08-12-2016 | 01:50 PM
  #1604
JayL's Avatar
Jay,
yes to make a loop
I have always just used strapping tape on the rim side
JayL is offline
Old 08-12-2016 | 02:57 PM
  #1605
I use Magic.
1.5 inches of battery strapping tape on the outside slightly heated to get the tape to be a little more tacky. No failures to date. I would use 3M 77 as mentioned,but I have no other use for a whole can of that stuff to warrant buying it.
