Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 07-30-2016 | 04:28 AM
  #2101
Originally Posted by Phillip F
YES!!! solves my motor high temp. My gearing and timing is perfect for the track I race at and was getting 167 temps after a 5 minute run. This will lower it down a bit. Thank you BOUCHER !!
Oh, don't give me credit for the idea. I was just passing on a cool idea somebody else had.
Originally Posted by dustneyes
I looked around the best I could, but I could not find... I have the aluminum "D" mount in my B6D. Is there a chart that shows the different settings (with corresponding toe/anti-squat) of pill settings for the "D" mount like they have for the "C" mount". I realize that having both, the combinations are endless, but just wondering if there was an additional chart with the "D". Thanks!
The stock plastic D block is the same as the aluminum D block using the center dot pill. Just use critical thinking to figure out changes in toe/anti-squat based off that.
boucher is offline
Old 07-30-2016 | 05:03 AM
  #2102
Just think about it a little more objectively.
The .5 pills make a certain amount of change, whether it's on the c or the d. The 1 pills make a larger change.
Socket is offline
Old 07-30-2016 | 05:10 AM
  #2103
Matt Trimmings's Avatar
Originally Posted by awidz
Yep this was rivkins car, he and cav do this
They mount the fan with double sided tape.
http://eos.redrc.net/2016/04/chassis...pencer-rivkin/
Matt Trimmings is offline
Old 07-30-2016 | 05:46 AM
  #2104
Motorman007's Avatar
What is the part that is holding the fan? I need 2 them for my 2 kits thank you sir
Motorman007 is offline
Old 07-30-2016 | 05:54 AM
  #2105
Those are b5m servo mounts. If you want the fan away from the motor more, use b6 mounts.
Socket is offline
  #2106
peter george's Avatar
Looks like a B5m servo bracket
peter george is offline
Old 07-30-2016 | 08:44 AM
  #2107
Originally Posted by Pistol123
I had similar running a dex210 on grass in mm3 , tried putting weight on the rear but it didn't sort it. In the end lengthening the rear camber links sorted. I'm not sure why but it appeared I was lifting the inside rest tyre on throttle. Night work similar on the b6.
And you know why? The front suspension was collapsing more than the rear, now with the longer camber link the rear collapses as much as the front. It's like Usain Bolt having a sore knee so the medic would bang the good knee with a hammer so they're both hurting
That's the big problem with setup, which end is causing us trouble? Which way to go?
In the end, removing a shim (-1mm for a start) from the front bulkhead would be much better than a longer camber link. BTW, I've handled and analysed dozens of cars and most of them suffer from front suspension collapsing because of low RC height and generally too soft a spring too, that's why most tend to run too soft a spring and lower(or more roll) roll centers in the rear, compounding the issue.
Hope it helps!
30Tooth is offline
Old 07-30-2016 | 09:00 AM
  #2108
Originally Posted by AZJP
Where do you get positive camber from that?
"Lengthening rear camber links ".. You get + camber. Shortening it... You get - camber.
Phillip F is offline
Old 07-30-2016 | 09:20 AM
  #2109
Pistol123's Avatar
Hope it helps!
Thanks, makes sense - will have to go away and have a think about those comments and get my head around it and try a different set up.
Pistol123 is offline
Old 07-30-2016 | 09:25 AM
  #2110
tsair's Avatar
Well, you obviously need to reset your static camber after adjusting the length. The length adjusts the camber gain as the suspension compresses, but you would want to set your static camber the same as before the change.
tsair is offline
Old 07-30-2016 | 09:27 AM
  #2111
RCBuddha's Avatar
http://users.telenet.be/elvo/
look in "setup guide" for info on camber links/link length and what does what.
I have other links on the first page that make for a good reading.
RCBuddha is offline
Old 07-30-2016 | 09:59 AM
  #2112
Making my way through the build and everything has been going very well. Kudos to Associated for making a pretty killer manual for this car. One problem I have run into though is my steering knuckles are pretty tight inside the c blocks. Did any of you run into this and did you loosen them up with a 3mm reamer?
Schuie Driver is offline
Old 07-30-2016 | 10:19 AM
  #2113
Of course. I usually install everything in the buggy ... Drop it like 12 inches down to my setup board then ... Then measure.
Old 07-30-2016 | 10:25 AM
  #2114
Wildcat1971's Avatar
Tech Prophet
yeah, I had this. It went away after a couple packs on the track.
Wildcat1971 is offline
Old 07-30-2016 | 10:35 AM
  #2115
tsair's Avatar
When he says "lengthen the camber link" he's talking about moving the inner ballstud towards a more inner hole (or the outer ballstud to a more outward hole). And then obviously lengthening the actual link to keep the same camber.
He's not just lengthening the link -- that would be referred to as adding "X degrees of camber".
tsair is offline
