Turnigy TrackStar ESC >
Like Tree4Likes
Old 07-05-2016 | 03:59 PM
  #376
Default Turnigy trackstar 120 turbo gen 2
Ok so mine is blue.so I purchased turbo 80\120 lcd card.doesn't work.purchased smart box,nothing...tried sub to computer.loads driver and nothing.read through all the computer tips on here and can't seem to make connection on how to install and run.just gives me this human interaction device thing.never mind,mine is a x car beast 120.
smash8ight is offline
Old 07-22-2016 | 08:41 PM
  #377
Hi
I have a problem with my trackstar smart programing box, esc gen ii 120a and a trackstar 10.5t brushless motor.
i have this combo on my trf417 and a tamiya tt02 type s.
I usually connect the programing box to the esc, to make some setup changes, but when i go to Motor Timing, it says "push to start", so i do it and then it says " sending to esc, please wait", the esc flashes once green and the red, and the time goes on and nothing happends.
i have tried taking the can timing to the minimium value, 0 and the maximium but i can not set up the motor timing.
Also i have the boost timing and the turbo timing just stock, i do not use them
I apreciate your help with this problem, i have wrote to HobbyKing and they already sent me a new smart box telling me that was the problem; i have tried this procedure with 2 or 3 smart boxes and the same happends.
Thanks for your help
ricardoguro is offline
Old 11-13-2016 | 12:51 PM
  #378
Default Trackstar 1/12 1s gen 2
Turnigy trackstar 1/12 1s gen 2, does the led flash in spec/blinky mode ? If so what color?
Lowefishme is offline
Old 12-05-2016 | 01:03 PM
  #379
I need to know this too, can't seem to get blinky mode, am I missing something?
Toasty359 is offline
Old 12-05-2016 | 02:16 PM
  #380
howardcano's Avatar
Check here: http://www.rctech.net/forum/14734227-post31.html
howardcano is offline
Old 01-10-2017 | 12:24 PM
  #381
Which 120amp is the newest? Or better 1?
Brushless 120amp Turbo V2(aluminum case)?
Brushless gen2 120amp?
Tanner3x is offline
Old 01-10-2017 | 05:18 PM
  #382
DJEckart's Avatar
Have good luck with my 120A Trackstar and Trackstar 17.5 in my Bandit for bashing... But one suggestion, take it out of auto LVC configuration and set it to 3.0 - mine would die out after a while, and then be ok once I restarted. Figured out what the problem was while racing my SC10 with a Hobbywing ESC/Trinity D4 setup and applied it to the Trackstar, all good now
DJEckart is offline
Old 01-20-2017 | 02:18 AM
  #383
MadRacer's Avatar
Originally Posted by Naters
I just got a tlr 22-4 and decided to try out a Turnigy Trackstar 120A turbo esc and 5.5. All I can say is wow. I'm totally surprised how smooth power delivery is and how controllable (for a 5.5 turn motor) it is. Does anyone know how the drive frequency setting affects power delivery? There were a few other settings on the programmer that I didn't fully understand but I can't recall right now...
What is a safe operating temperature for the esc's? I temped mine on a couple of runs and it was around the 120 degree F mark.
The higher the Frequency the smoother the power delivery is.
Good for low traction conditions. You will notice you have to apply more throttle input for the same speed you are use too. I like 8KHZ which is default setting. Same for the brake frequency .
MadRacer is offline
Old 01-22-2017 | 10:41 AM
  #384
I have a trackstar turbo v2. The throttle cuts in & out??
Tanner3x is offline
Old 01-23-2017 | 07:54 AM
  #385
sacmiata's Avatar
Only have had v1's. The only time mine ever did this was if I had the turbo set to high. I think it would over clock past 60' and cause it to stop then all of a sudden accelerate again.
I would take out all timing and just use the endbell first. If that fixes it then add boost/turbo slowely.
Also could be the low voltage cutoff is to sensitive. Try lowering to a minimum.
sacmiata is offline
Old 02-10-2017 | 10:12 PM
  #386
Hi - I have 2 Turnigy Trackstar Turbo 80a esc and I am facing following issue on both : when I go reverse, I can not go forward before the car stops. This is a big issue as there is no way to brake before car stops by itself. Note that I do not have this issue with my other esc and I have done proper calibration on both.
How can I change the settings to avoid this ?
Julien
julieng is offline
Old 02-11-2017 | 07:12 AM
  #387
dtr's Avatar
dtr
You need to reverse the throttle channel on your radio and recalibrate the esc to it.
dtr is offline
Old 02-11-2017 | 07:24 PM
  #388
I tried but I can not calibrate it forward once I reverse the throttle channel.
julieng is offline
Old 02-11-2017 | 11:47 PM
  #389
dtr's Avatar
dtr
Bummer. What tx and rx are you using?
dtr is offline
Old 02-12-2017 | 01:09 AM
  #390
Both are Spektrum
julieng is offline
