Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 07-10-2016 | 03:35 PM
  #1936
Looking forward to picking up one of these buggies sometime next week. I'm at page 70 so far through the thread and learning lots already.
SLO county race is offline
Old 07-11-2016 | 05:40 AM
  #1937
what position are you guys running the battery in?it seems there is about 10-15 mm that the battery can be used in either direction.im struggling to get a planted feel with this buggy so far.ive tried the box setup and joes snats..it never feels like it has really good grip.ive tried several tires and only get marginal improvement.
hanker39 is offline
Old 07-11-2016 | 06:05 AM
  #1938
I run my battery all the way back and it felt alittle different but nothing eye opening.
GettinLapped is offline
Old 07-11-2016 | 08:50 PM
  #1939
proliteandsc's Avatar
Default tini coated shock shafts
Are the tini. Coated shock shafts stronger then the none coated ones? Is it the same steel shaft with a coating?
proliteandsc is offline
Old 07-12-2016 | 06:20 AM
  #1940
I'm not sure that they are tons stronger, but when coupled with the delrin inserts, they are considerably smoother.
I will tell you that it's a good idea to keep a spare set of shock shafts on hand. I've bent 1 front shaft between my EB and NB this summer and it was on a horrific crash.
Bob Barry is offline
Old 07-12-2016 | 02:15 PM
  #1941
justpoet's Avatar
While this may be a bit stiff in spring/oil for your track if it is rough, give this a shot if you've been working with the other pro setups and just can't get a handle on rear traction. I've often had people tell me it is the easiest to drive buggy they've ever tried. Obviously use appropriate tires for your track. I ran this setup mostly on medium traction.
Attached Thumbnails Tekno RC EB48.3 Thread-stablestart-eb48.3-davehemenway.jpg
justpoet is offline
Old 07-16-2016 | 02:06 AM
  #1942
werner sline's Avatar
awesome tailwhip with a eb48.3, really extrem, very nice driving there !
+ YouTube Video
werner sline is offline
Old 07-16-2016 | 11:41 AM
  #1943
DRJVogel's Avatar
Yes! That was truly awesome! Wow! Watch out Slo-Mo Guys!
DRJVogel is offline
Old 07-19-2016 | 05:06 AM
  #1944
mxrcracer23's Avatar
Finally got the buggy built and on the track this weekend. I used the wicked weekend nb setup and was very impressed with the car, it was extremely stable through every section of the track. I changed to a JC hybrid wing which seemed to give it good rotation in tight turns. The only thing the car seemed to lack was forward bite. I will be looking at wheelbase and diff adjustments next time out
mxrcracer23 is offline
Old 07-20-2016 | 01:18 PM
  #1945
Default Turn on power?
Got my car to turn nice in off power tight turns, but pushes bad on wide turn. Anyone have any suggestions how I can get it around wide turns without compromising it's tight turns and jump ability?
Old 07-20-2016 | 01:30 PM
  #1946
We really can't give suggestions without knowing the entire setup, track surface, tires, etc. Best thing I can tell you is show us a quick vid of the track and link your setup. Then we can offer advice.
OR just put Joe's Southern Nats setup on your car with some Blue Reflexs or Blue Triple Dees on your car and be dialed
Old 07-20-2016 | 04:24 PM
  #1947
Stubbs's Avatar
Maybe it's just mine and my buddy's 43 year old, slow-arse reflexes, but we both found Joe's setup very twitchy, and difficult to drive consistently.
We went back to the box set up, and did a little tweaking from there, and it's much better for us "old guys".
Stubbs is offline
Old 07-20-2016 | 04:51 PM
  #1948
DRJVogel's Avatar
Originally Posted by Stubbs
Maybe it's just mine and my buddy's ... slow-arse reflexes ... us "old guys".
I resemble that remark!
DRJVogel is offline
Old 07-21-2016 | 07:34 AM
  #1949
Haha...can't be. I'm 42 and I love his setup...lol. I do have a ton on expo on my steering (M12 - 60%), but I'm also running a protek 150t servo.
Seriously, yeah posting your current setup sheet will probably be the best way to get help.
qstorm777 is offline
Old 07-21-2016 | 02:05 PM
  #1950
I started with Joes Southern Nats and made a few changes.
Front arm shock mount is A.
2mm rear wheel offset.
Front shock 32.5 AE
Rear shock 37.5 AE
Diff 7,10,3 AE
Track is outside smedium dusty hard packed clay, sometimes wet. I guess about medium grip.
I tried calibers, subcultures, hole shots, crime fighters, sweeps, all about half worn.
I did notice the servo saver could be made tighter. That might help. I'll try that next time I race.
Anyone have any ideas what I need to change to get this car around wide turns? It pushes when turning on power.
