Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 07-16-2016 | 04:39 PM
  #1621
GeorgePravata's Avatar
How do you check toe in and toe out on the front or check rear toe..You eye ball it
GeorgePravata is offline
Old 07-16-2016 | 05:06 PM
  #1622
aeRayls's Avatar
You never need to check rear toe. Front I eyeball and then get it all setup with a set of calipers. Camber is easy, $5 aver gauge, done.
In 23 + years never needed or wanted a setup station, still don't know one person that runs off-road that uses one.
aeRayls is offline
Old 07-16-2016 | 05:36 PM
  #1623
suby723's Avatar
I check toe with a camber guage. Turn the car on and put both front tires one the edge of a table. Then put the camber guage on the inside of the wheel and the table. This method is very accurate, never trust eyeballing it.
suby723 is offline
Old 07-16-2016 | 06:49 PM
  #1624
I just need some one to check the rear toe thats all I'm looking for KIT set up 2.5* toe and 1* anti sq. I can't get that for nothing I have the C block and the alum. D block I had to walk away from it for a while needed a break
Old 07-16-2016 | 06:55 PM
  #1625
Fabulous's Avatar
Originally Posted by RCBuddha
can someone post a picture of the exotek servo horn on their car?
I have zero issues using the Exotek servo Horn.
Attached Thumbnails Team Associated B6 & B6D thread-20160716_204010_resized.jpg   Team Associated B6 & B6D thread-20160716_204141_resized.jpg
Fabulous is offline
Old 07-16-2016 | 07:12 PM
  #1626
RCBuddha's Avatar
Thanks! I added the horns back to the front page.
RCBuddha is online now
Old 07-16-2016 | 08:19 PM
  #1627
pink_sleeve's Avatar
Looking to try out carpet off-road for the first time. If guys at the track are running Proline pinpoints and wedges is it safe to say Schumacher Staggers and Mini Pins will work?
pink_sleeve is offline
Old 07-16-2016 | 08:22 PM
  #1628
tsair's Avatar
Excuse the dumb question, but can I use electrical tape to tie the 3 motor wires together for neatness instead of shrink wrap? Or is the heat through the insulated wires going to melt the tape? This is on 17.5...
tsair is offline
Old 07-16-2016 | 08:38 PM
  #1629
it's probably in here somewhere but I couldn't find it sorry
Where do you put the 1mm shims to be able to run the MIP pucks on B6/b6d ?
Fabs is offline
Old 07-16-2016 | 08:42 PM
  #1630
elex300's Avatar
Here are the shims but no pic of where the go.
http://us1.campaign-archive2.com/?u=85cdb852b7a2a0f636574b1ce&id=400fff7b1c
elex300 is offline
Old 07-16-2016 | 08:48 PM
  #1631
http://miponline.com/store/mip16085
That's the link to mip's online store. It's a shim kit. Cost is $9.00
Chris Brown is offline
Old 07-16-2016 | 08:49 PM
  #1632
Electric tape will be fine. Just might not look as neat.
Old 07-16-2016 | 08:58 PM
  #1633
abailey21's Avatar
Gimme an hour or so, I picked one up today
abailey21 is offline
Old 07-16-2016 | 09:11 PM
  #1634
tsair's Avatar
Cool, thanks for the info!
B6 is crazy... completely stock (except for slipper eliminator) with full size shorty, full size servo, big receiver (RX-462), and a temp sensor, voltage sensor... weighs in at 1508.
tsair is offline
Old 07-16-2016 | 09:56 PM
  #1635
http://us1.campaign-archive2.com/?u=...&id=400fff7b1c
Large shims go inside the gearbox case on the outdrives, against the bearing, I'm guessing the smalls one go on the end of the dog bones / axel inside the rear hub. The MIP B5 ball diff is about 4 mm narrower than the B6 ball diff. The B6 also has 2mm shims for the gear diff that you can use with the MIP unit. Associated also has a diff shim part # 1733, but they are really thin, might work out on the hub side.
Just built my B6 with B5 MIP bimetal diff, spacers from the gear diff, no spacers on the hub side yet. I think it's going to be OK, at full droop the flats on the puck are fully inside the outdrives. Hobby shop was out of PN 1733 so I will add when they come in.
belewis01 is offline
