Soldering Motor
Old 06-13-2016 | 05:56 AM
Default Soldering Motor
I need to desolder my motor. Do I need to re-tin the wires prior to reinstalling them on the motor tabs? Or is the existing solder good enough? I'm trying to avoid a big glob of solder on the tabs.
Thanks !
Miko1976 is offline
Old 06-13-2016 | 08:15 AM
Thanks !
Existing solder is fine. You may need to add a bit if necessary.
Andy Koback is offline
Old 06-13-2016 | 02:35 PM
Default Tinning the Motor Tabs?
I've seen some guys tin the motor tabs but others don't. Which is the best/correct way.
Thanks again!
Miko1976 is offline
