Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree653Likes
Last edit by:
Print Wikipost
Old 06-01-2016 | 08:49 AM
  #676
Wildcat1971's Avatar
Tech Prophet
Originally Posted by weedsnager
Thanks for all your help....
I'll be using a spektrum radio and a Blackbox 800Z Zero-Timing ESC
Voltage Input: 7.4V, 2S LiPo
On Resistance: 0.0004
Continuous Current: 80A
Dimensions: 1.6 x 1.2" 0.74" (40.2 x 31.0 x 18.8mm)
Weight: 1.3oz (37g)
Motor Limit: 10.5T
SBEC: 6.0V/3A
A savox 1258 will be fine for you. they are cheap and pretty decent for 1/10 buggy.
https://www.amainhobbies.com/savox-s...1258tg/p183316
Wildcat1971 is offline
Old 06-01-2016 | 09:09 AM
  #677
WillS's Avatar
Originally Posted by Kraig
I primarily look at the speed, torque and the voltage that the servo is rated at. Right now, I am at least looking for a speed of .10 seconds, torque of 100 ounce inches, at 6 volts. I say 6 volts because that is what my speed control b.e.c. is supposed to be able to supply.
Some speed controls only supply 5 volts and some receivers can't handle voltages above 6, but they are getting to be few and far between.
If you can share what radio system and speed control you are using we can let you know if there might be compatibility issues.
I have used Xpert servos with great success. If you want a shorty, the Pi-3402 ($105) is a great choice. If you want a full size, the Si-4431 ($80) is a perfect fit. Both operate faster than the speed and have more torque than you are asking at 6V. I find they draw very little power over a run.
I ran these before I was sponsored because I was tired of Savox needing high voltage/amperage and the price range of the KO servos.
WillS is offline
Old 06-01-2016 | 09:55 AM
  #678
5tone's Avatar
plus one for an xpert servo
pretty high quality en perf. for the half price of a fut. or ko.
...and not noisy...
5tone is offline
Old 06-01-2016 | 11:24 AM
  #679
I'm looking at the D version, for some light racing. I don't need anything fancy, just the most reliable servo that won't break the bank, I'd like to stay under $100
Ryan Cavalieri is running the Savox 1258t, a $60 servo. So thats a pretty cheap servo that can be used at the highest level
mgers75 is offline
Old 06-01-2016 | 11:47 AM
  #680
And to anyone who says it doesn't work with Spektrum: I use it that way. The only problem I can confirm is when using cheap ESC's!
man1ac is offline
Old 06-01-2016 | 06:34 PM
  #681
I have a savox in another car with spektrum gear, works fine with a glitch buster....thanks for the recommendations guys
weedsnager is offline
Old 06-01-2016 | 06:48 PM
  #682
RCBuddha's Avatar
Originally Posted by boucher
Could we also get the setup database added to the first page? Not much there now, obviously.
http://site.petitrc.com/setup/associ...tedRC10B6.html
added
RCBuddha is offline
Old 06-01-2016 | 06:52 PM
  #683
RCBuddha's Avatar
I'm a fan of the XP 1015 and 1013; but the Reedy Servos seem to priced comparably. Protek is next on my list to try.
RCBuddha is offline
Old 06-01-2016 | 09:32 PM
  #684
Whig protek? The 160ss?
Slashn77 is offline
Old 06-02-2016 | 02:50 AM
  #685
xyzracer's Avatar
I run a protek 130ss in a couple of my cars and it's awesome but you need a stout BEC to run it because it draws such a high current. I run these with my tekin gen 2s because of the 5 amp BECs. I run savox 1258 or spektrum 6040/6240 with my hobbywing escs with no problems as well. All using airtronics radios.
xyzracer is offline
Old 06-02-2016 | 05:04 AM
  #686
elex300's Avatar
Originally Posted by dustneyes
I realize that there is no gear cover for the lay-down transmission because it was born from the carpet world, but those that will be running it in there B6D... Will there be a gear cover for the spur and pinion for those running in the dirt?
The body doesnt cover the spur gearon a traditional stand up transmission so you use a gear cover. On the laydown transmission the body is designed to cover everything. No need to cover it twice.
elex300 is offline
Old 06-02-2016 | 06:30 AM
  #687
Tech Prophet
I like the specs on the 160T. Good speed and torque.
Old 06-02-2016 | 10:03 AM
  #688
Yeah me too I just would never need that much torque in a 1/10 scale
Slashn77 is offline
Old 06-02-2016 | 10:31 AM
  #689
Tech Prophet
and you would need the speed more?
Old 06-02-2016 | 12:52 PM
  #690
Finalist's Avatar
I'd love to see that servo opened up to see what's inside of his version. Could be the same retail thing, but I would not be surprised at all if it used higher quality stuff -- a very typical move in all sports and hobbies.
Finalist is offline
