Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 05-12-2016 | 01:21 PM
  #27541
Does anyone know what weight the Tamiya m-chassis hop up springs are? I've got red and yellow and want to be able to cross reference to other brands.
matrix101 is offline
Old 05-12-2016 | 02:04 PM
  #27542
monkeyracing's Avatar
Originally Posted by monkeyracing
Anything with less turns will run faster. 12 turns will be a little nutty. Nothing wrong with nutty.
Depends which one you've got. The 104 was good down to 23, maybe 20 turns.
Which hop up springs? They've made so many versions!
Spring Rating [lb/in]
These ones are TC length, but usable.
Purple 22.72
Gray 20.91
White 14.82
Never seen this in a set.
White Short 17.24 (53633)
Short touring car spring set. "Dull" colours..
Blue Short 15.27
Yellow Short 13.24
Red Short 12.90
Touring car spring set. Fluoro colours. 53333 (short, but not as short as the ones above)
Blue 14.08
Yellow 13.33
Red 11.86
These, as far as I know, are comparable to the short touring car spring set. Maybe a little firmer)
TRF 84117 M chassis white set
TRF 42168 M chassis black
TRF 47314 M chassis mica blue
monkeyracing is offline
Old 05-12-2016 | 02:51 PM
  #27543
OK, I wasn't aware there was several types. All I know about these is they are the genuine Tamiya hop-up springs for the M-chassis. I'll do some more digging.
Old 05-12-2016 | 04:44 PM
  #27544
gigaplex's Avatar
If they came in a set of red/blue/yellow and they're fairly bright in colour, they're most likely the 53333 set.
gigaplex is offline
Old 05-12-2016 | 06:41 PM
  #27545
These are a black spring, with a small dab of colour painted on to indicate the spring. I've used 3 racing springs before too, but I cannot find any info on the weight of the spring, so it makes comparisons tricky.
Old 05-13-2016 | 06:55 PM
  #27546
So for the tamiya m05....I do not recommend a blitz RS1 body. Mounted like absolute crap. The wheel bases are off of the arches and everything. It is just terrible....what body's come with pre drilled holes or are a reputable company that fit nice?
M05 newbie is offline
Old 05-13-2016 | 09:36 PM
  #27547
(0000000000)'s Avatar
Many racers I have come across have had positive experiences with Blitz RS1.
If you are looking for something that is easy to cut and mount, I would recommend Tamiya bodies, like the new Miata.
My body of choice for the past couple years has been the Ride Subaru BRZ. Very easy to cut/mount.
(0000000000) is offline
Old 05-13-2016 | 09:38 PM
  #27548
Old 05-13-2016 | 09:41 PM
  #27549
Ya it's weird my wheels are like tucked in weird. Measured the holes nice and everything. It's just maybe 4mm too long and I've swapped the wheel base. I'll use it and see how it is because I tinkered and got it to fit without rubbing I think so it might not be so bad after said and done.
Old 05-13-2016 | 09:44 PM
  #27550
Hmmm thats the Subaru body?? Looks good. Might check that one out too. I got a bigger motor so I'm sure I'll need some bodies once its in haha
Old 05-13-2016 | 11:12 PM
  #27551
OVA's Avatar
OVA
Congrats your win.thats awesome..btw what is the wheel base for the bodies?
thanks
OVA is offline
Old 05-13-2016 | 11:46 PM
  #27552
Thanks Franko, but if you're not first, you're last.
LoL
I run the medium wheelbase on that subaru body. But it can also accept a short wheelbase.
Old 05-14-2016 | 12:46 AM
  #27553
RS1 should fit easily, with loads of room to spare in the wheel wells. I found it pretty easy to set up.
On the one pictured below, I've got 7mm wheel hexes, slammed the body down using M03 front body mounts on the rear and lopped off 5-10mm from the bottom edge of the shell. Wheels still tuck in perfectly.
Fitting shells can be tricky and frustrating. I've screwed up a few.
Old 05-14-2016 | 06:27 AM
  #27554
See my back wheels are weird. There's lots of room for the wheels but the whee wells didn't line up in the back when the fronts did. I just cut some more out because good chance it breaks anyways and I'm learning still. Might try the Subaru body next. Do body posts bend easily? Wondering if that's my issue maybe?
Old 05-14-2016 | 06:57 AM
  #27555
I just bought a Mazda Miata M05 ($85 from Tower!). I'm going to run it in front of the house or in parking lots but no plans to race it. I'm thinking that I will add oil shocks (Tamiya, 3Racing?) and maybe just a Sport Tuned motor. Any suggestions additional items that I should buy right away (bearings of course)?
Also, is the Tamiya 53619 Mini Shock Unit the correct oil shocks for this?
CTRJ is offline
