Like Tree2991Likes
1/12 forum
Old 04-06-2016 | 03:18 PM
  #44251
Dr Vink has spoken !!
Racermac73 is offline
Old 04-06-2016 | 03:30 PM
  #44252
ShadowAu's Avatar
Originally Posted by avink007
BSR/CRC/Jaco Black front tires will calm the front end down. You could also try gluing the outer sidewall of your current tires with CA. Maybe try a different rear tire too, like a BSR/CRC/Jaco Pink or Magenta.
Of the 3 different brands which starts out the biggest diameter? Running outdoors I can afford to start tires bigger than on carpet
I think the Tamiya rears are pretty close to a yellow (according to those that know more than me) - I've tried Jaco Pinks before but not on this surface.
ShadowAu is offline
Old 04-07-2016 | 04:42 AM
  #44253
I'd like to know if you produce or you will produce an alu lower chassis for serpent s120 LTX. Thank you in advance.
Originally Posted by jason cheng
ok the brand new X-ray chassis ready to roll only 24 made 14 left for sale post on here if wanting one.
NEW PRODUCT!
Introducing the new Aluminum Chassis for the XRAY X12 2016! Made from premium 2.5mm thick 7075-T6 aluminum so you can run your stock lower pod plate machined to perfection! Works extremely well on medium-high bite tracks. Generates more traction while at the same time making the car faster and easier to drive.
Features: Anodized Black plate milled down front arms pockets .50 so you can run smaller tires.
•Optimized cutouts for dynamic flex
•Optional holes for direct servo mount to chassis
•15g heavier than standard XRAY carbon chassis
•Lower center-of-gravity
moraccio is offline
Old 04-07-2016 | 05:12 AM
  #44254
Aza088's Avatar
Pick up some ULTI Z compound rears.
You will thank me later.
Aza088 is offline
Old 04-07-2016 | 06:34 AM
  #44255
i was about to pull the trigger on those springs then the cheap side of me saw the almost $10 in shipping...i'm about to see if i can find another avenue lol
phatboislim is offline
Old 04-07-2016 | 09:04 PM
  #44256
Dray01's Avatar
+1 Very good for outdoor!
Dray01 is offline
Old 04-08-2016 | 06:04 PM
  #44257
ShadowAu's Avatar
Good advice IF any of the hobby shops I have access to (both online and local) had them or could get them.
I can get X and J soft and X supersoft
ShadowAu is offline
Old 04-08-2016 | 07:53 PM
  #44258
Aza088's Avatar
Call Walter RC Hobby. (02) 9632 8733
Ask for Jay, The Z compound is normally a too order item as they are not cheap.
I have placed and order for the NSW titles and ULTI will be shipping them this week (i believe). They should arrive end of this week or early next week.
Trust me on low grip asphalt or painted fake asphalt nothing compares.
Aza088 is offline
Old 04-08-2016 | 08:42 PM
  #44259
dirtdynamics's Avatar
What would be an essential tool combo for 1/12?
dirtdynamics is offline
Old 04-09-2016 | 02:14 AM
  #44260
NomadRacer's Avatar
One essential tool would be the right size wrench for your steering turnbuckle/tie rods.
NomadRacer is offline
Old 04-09-2016 | 07:21 PM
  #44261
ShadowAu's Avatar
Thanks - I knew Walter had the other compounds but didn't know about the Z's
ShadowAu is offline
Old 04-10-2016 | 04:17 PM
  #44262
Fredp1's Avatar
Jay from Walter RC got some Z softs in for my son. Great service from Jay.
Ran them at the Victorian State titles over the weekend with geat results.
When the track was sugar sprayed the night before, had to glue the front JH and trued 2mm off to stop traction rolling. During the finals, ran the tyres straight out of the packet.
Fredp1 is offline
Old 04-10-2016 | 06:37 PM
  #44263
has anybody got any news about the release of the new Yokomo 1/12th scale car?
vafactor is offline
Old 04-10-2016 | 07:00 PM
  #44264
EDWARD2003's Avatar
Yes, it will be released end of May or early June. Just in time for the JMRCA 1/12th Nats.
I've heard the rear pod is a bit of a pain to build and set square.
EDWARD2003 is offline
Old 04-14-2016 | 03:21 AM
  #44265
Fredp1's Avatar
Default New VBC LightningM 1/12 car
Just saw this announcement on a new VBC pan car.
http://www.vbcracing.com/products/li...-d-05-vbc-ck18
Fredp1 is offline
