Tekno RC EB48.3 Thread
#1336
I run the SMC 3600mAh packs with the tekin T8i indoor motor and make a 10 min main fine. They are half the weight of the normal batteries and that will affect your setup, so switching back and forth probably wont work too well.
#1337
Do any of you guys use SMC Batteries? Im trying to decide which of theirs I should grab. The lowest MAH ones are 34 bucks will those be enough to get me by? Im trying to justify the extra cost Im usually running 15 minuts of practice per battery and the heats / mains at my track are 6 and 8 minutes
#1338
#1339
#1340
Im gonna be running them with a trackstar esc and motor or tekin gen2, havent decided yet
#1341
This is still basically the same as Lutz uses now. Drag Brake does get adjusted per track based on the feel he wants. http://www.teamtekin.com/hotwire/esc...nLutz_v249.pdf
#1342
It can help. I run between 5 and 10 most of the time. The only time it messes me up is if there are really big jumps and I forget to hold a little throttle. Some of my drag brake induce lawn darts have been pretty epic.
#1344
#1345
#1348
I bent on in my first race with it and I've just found one on the front. I'm really not liking this trend. This car has only been raced 4 times. I ran a whole season with my sworkz and only bent one on that car during a fast head on when another buggy crossed the pipe onto the straight. I just don't understand how a car of this quality has this issue. Are they just too long for a buggy?
#1350
22Likes
