LifePo4 Battery to replace 4AA's >
Old 03-01-2016 | 09:56 AM
Default LifePo4 Battery to replace 4AA's
So after more time than I care to invest searching for an answer to this I decided to ask a question.
I have been using a LifePo4 pack in my Futaba 3PL transmitter and am pleased with the results. I am now wanting to source one for my sons' car and am running into an issue.
Does anyone know of a 6.6V LifePo4 battery pack that will fit in the same space as a 4AA cell battery holder? Preferably one with a 2 pin red plug on it.
The physical dimensions really need to be within a length of 60mm, width of 55mm and height of 16mm.
I'm sure there may be some really small ones out there that fit but I was hoping to find something over 1500mAh.
Anyhow thanks for any info.
BoostCreep is offline
Old 03-01-2016 | 10:15 AM
tsair's Avatar
Can you point to the lifepo you are using in the 3PL? I have the same radio and would switch if there were an adapter or something that fit well.
tsair is offline
Old 03-01-2016 | 12:21 PM
I'm using a Turnigy nano-Tech 2100 mAh from Hobbyking. Paid about $14 for it. It wasn't plug and play however. I had to cut the wires on the original battery holder and put the Futaba connector on them so I could plug the battery in. It was simple to do and works perfectly.
Old 03-01-2016 | 02:28 PM
tsair's Avatar
Thanks, I don't mind putting on my own connector, does the battery fit pretty well or did you need to use foam spacers and such?
tsair is offline
Old 03-01-2016 | 02:52 PM
tsair's Avatar
Check out the Hobbico LiFe's on eBay, the 1300mah and 1100mah are close, but a little big in one dimension or another.
tsair is offline
Old 03-02-2016 | 10:21 AM
It is not a perfect fit in that you do need to support it with foam. But all in all that's a really minor issue.
And thanks for the heads up. I'll look through those.
