Tekno NB48
#3452
You posted NT, but then mention buggy in the next post, do you mean truck or buggy? If it's the buggy, there were a TON of changes and coming from original to .3 I would definitely buy new personally. Truggy, it could be bought new or upgrade, depends.
#3455
Got it. Yes, I would do what I recommended then. FYI, this is the NT48 thread:
http://www.rctech.net/forum/nitro-of...48-thread.html
Hey Matt, these are the current EB48.3/NB48.3 thread, which will be what most people are watching. In the end, you can make them drive somewhat similar (with obvious differences in power curve), so it's all about what racing you have local and what you're most comfortable with.
http://www.rctech.net/forum/nitro-of...-3-thread.html
http://www.rctech.net/forum/electric...-3-thread.html
#3457
I realize that all of the cool kids have moved on from the EB/NB 48.1/.2 to the .3, but being cheap, I'm using the older models.
Has anyone run the JN2 rear suspension shims on the older models? I understand that they are supposed to make the .3 easier to drive on power with more corner speed.
#3458
Most drivers that I've had contact with have been very happy with the .3 testing and the various aftermarket 1.5 spacers and using other smaller 1.5 shims.
#3459
#3463
Are you talking about the shims that guys were putting under the rear diff case? If so, the hubs are just a better way of accomplishing basically the same thing. Using both together might be too much of a change in most cases.
#3465
Those that have had the NB48 version 1, had you had to clearance your chassis for the starterbox wheel? I have gotten a chassis, yet it has been beveled to accomodate one. I have a new replacement chassis on the way. Also what is the best size flywheel to run with the stock motor mount?
Thanks everyone
Thanks everyone
12Likes
