Tekno RC EB48.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree22Likes
Last edit by:
Print Wikipost
Old 11-20-2015 | 03:43 PM
  #721
Matthew_Armeni's Avatar
Originally Posted by Ruffdog1
does anybody like SMC Lipo's or are they a waste of money? I have always bought higher priced/name brand batteries. Is it worth it? Thanks!!
That's all I run Most of the Tekno team runs SMC. Good packs, good prices, god customer service.
Matthew_Armeni is offline
Old 11-20-2015 | 04:10 PM
  #722
I'm having trouble picking a steering servo. I'm leaning toward the Savox 2273SG. My question is will I have brown outs with it? I'm going to be running the futaba 4pk for my radio and the tekin motor and esc. I think I have to switch the bec on the esc to 7.4v. If I do that will I still get a brownout? Should I also get a glitch buster for peace of mind?
EricM is offline
Old 11-20-2015 | 04:44 PM
  #723
Not heard any complaints from brown outs with anything other than Spektrum's older gear. Not experienced a glitch with any of my receivers running on 2.4GHZ. The old days with brushed motors, another story entirely. I wouldn't worry about it, build the setup and deal with any troubles if you experience glitches. The 4PK is a very good radio and not likely to experience any troubles with it in your buggy.
Everyone is going to suggest what ever brand they are currently having good experience with when talking electronics. For me, I have had good luck with Airtronics and Futaba servos, just pricey and I do not think they perform as well in their given price points against brands like Savox, Protek and my current favorite, MKS. MKS is right up there with the top of the line Airtronics and Futaba servos, I just like their build quality better on the MKS, about the best I have seen but they are pricey.
http://www.amainhobbies.com/rc-cars-...hbl599/p451000
Specifications:
Torque:
@6.0V: 416.62 oz-in (30 kg-cm)
@7.4V: 527.72 (38 kg-cm)
@8.2V: 583.27 (42 kg-cm)
Speed:
@6.0V: 0.11 s
@7.4V: 0.09 s
@8.2V: 0.08 s
Weight: 73.12 g
Dimension: 40x20x38.5mm
Working Voltage: 3.5 ~ 8.4 V (2S LiPo unregulated)
Working frequency: 1520μs / 333Hz
Dead Band: 0.0008 ms (Default)
Bearing: 2BB
Motor: Japan High Quality Brushless Motor
Gear: Chrome-Titanium alloy gear
Fasttrak is offline
Old 11-20-2015 | 06:27 PM
  #724
mkl
Although I have not experienced it directly, I have read on many other threads that people have a lot of brown out issues with Savox. Apparently they are power hungry. I have also heard of issues with Spektrum equipment. I do have Spectrum and I have never had one glitch, so I would say that it is not universal. I have run Spektrum and ProTek servos (all with RX8 ESC) and have had no issues at all.
Others have said adding a glitch buster cap will help with the brown outs.
mkl is offline
Old 11-20-2015 | 08:00 PM
  #725
Sroufe7's Avatar
Same as what others have said, SMC are great. I've been running them for a couple of years and have absolutely no complaints.
Sroufe7 is offline
Old 11-20-2015 | 08:03 PM
  #726
I've been running the savox brushless 2274 and 2273 in my sct and ebug for 3 years and never had a problem. Just used rx8 gen2 on 7.4v bec.
qstorm777 is offline
Old 11-20-2015 | 08:47 PM
  #727
vwduud's Avatar
I use both of these in my buggies and truggies with Futaba (4PK and 4PX) powered by both Tekin Rx8 (Gen 1 and 2) as well as a HobbyWing SCT Pro. No brown outs.
vwduud is offline
Old 11-20-2015 | 09:47 PM
  #728
MOE's Avatar
MOE
I'm pleased with the performance of my smc batteries. As far as servos go I'm running a savox 2273 with and RX8, kopropo radio.
Never had any glitch issues on 6v or 7.4v
MOE is offline
Old 11-21-2015 | 09:25 AM
  #729
Ruffdog1's Avatar
Do you charge your SMC Lipos at more than 1C? Thanks!!
Ruffdog1 is offline
Old 11-21-2015 | 11:03 AM
  #730
Thanks for the comments. I think that's the servo I will get.
EricM is offline
Old 11-21-2015 | 12:00 PM
  #731
Yeah, depending on the battery I'm charging. My charger maxes out at 10 amps (regardless of overall wattage) so my 7200's aren't getting 14 amps. But my 4400 shorties I charge at 10 amps. My 2200 shorty 4s packs I charge at 5 amps.
At a big race when I forgot to charge my battery I used my friends setup to charge my 6500 4s packs at 40 amps, so they can handle it.
Old 11-21-2015 | 02:55 PM
  #732
You shouldn't have any brown out issues with the Futaba radio, or any other high end radio for that matter. The Spektrum radios have issues with them. You will get more performance from the servo at 7.4v.
MX304 is offline
Old 11-21-2015 | 03:41 PM
  #733
I had brown out issues with Savox while using Spektrum. Switched to Futaba and haven't had a single issue. I use the 2274 and 2273 in both my nitro cars and my Futaba handles them flawlessly.
Tbyrne1976 is offline
Old 11-22-2015 | 07:04 AM
  #734
rcnut87's Avatar
I bought the new .3 hinge pin holders as well as the .3 upgrade kit from fierce rc last week. I went to start installing and when i pit the front together i noticed alot of front to back slop in the arms. Seems like the hing pin holders are not getting tight enough on the arm. Looks like i may have to shim these. Has anyone else had this issue upgrading there .2 to a .3?
rcnut87 is offline
Old 11-22-2015 | 07:13 AM
  #735
There should be a small amount of forward/backwards play, but not excessive. New arms or old? Are they worn, specifically the bump out that would be near the insert?
RokleM is offline
