Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 09-24-2015 | 08:40 AM
  #25756
sakadachi's Avatar
Originally Posted by OVA
I do have the TA03 in hand.. So most of the mini driver perfer to use the
TA03 ball diff their first option than the Gear diff?
I'm not sure if most people are even aware of the monkeyracing gear diff approach. I've thought about something like that while back, but hadn't tried it until recently. It works, and it works quite well. If you are referring to the oil gear diff, if the diff doesn't leak, I much prefer the oil diffs vs ball diffs for its consistency and very low maintenance.
If you race TCS you might be outside the guidelines so best to check your options. I'm open to any mod since I don't race these days.
I had a few weekends to stop by the local parking lot track to watch or even participate if I had urge, but ended up doing other things. Racing is not a big factor in my RC right now, I just enjoy putting them together, fiddling around with it, and just driving them around for personal enjoyment.
sakadachi is offline
Old 09-24-2015 | 09:02 AM
  #25757
godzukihop's Avatar
Is it possible to post a ling to the monkeyracing gear diff approach? I tried the search tool, but no luck.
godzukihop is offline
Old 09-24-2015 | 09:10 AM
  #25758
sakadachi's Avatar
You just add more of these shims highlighted yellow. I used 2 per side for a nice weighted feel on my near stock M05, you can do 3 per side and work the small screws to get your range of adjustment.
I'm going to make the shims out of transparency film and stack them up until I get the resistance I want.
http://www.rctech.net/forum/members/...2097-shims.jpg
Old 09-24-2015 | 09:32 AM
  #25759
godzukihop's Avatar
Thank you.
Old 09-24-2015 | 10:01 AM
  #25760
monkeyracing's Avatar
A few extra shims per side, with a tiny smear of anti wear grease. Make sure the screws are tightened very evenly. I wouldn't go so far as to call this the Monkeyracing diff. I learned about it on the forum and just advocate it where there might be a conflict with chassis, budget or rules.
monkeyracing is offline
Old 09-24-2015 | 11:33 AM
  #25761
eR1c's Avatar
I would probably enjoying racing at home if I had a nice track like you too!
eR1c is offline
Old 09-24-2015 | 11:56 AM
  #25762
sakadachi's Avatar
Originally Posted by monkeyracing
A few extra shims per side, wi h a tiny smear of anti wear grease. Make sure the screws are tightened very evenly. I wouldn't go so far as to call this the Monkeyracing diff. I learned about it on the forum and just advocate it where there might be a conflict with chassis, budget or rules.
You're too modest. To me this is the "monkeyracing diff", so that is what I will be referring it to it as. It's a great mod especially on my trucks where they dont necessarily offer ball diffs as an option. Plus it costs nothing, really. It's great.
Thanks, eR1c. I can't wait to expand it some more, tentatively next Summer I will start the other section. I'm thinking about adding a grade on one area of the track to give it a mild 4-5" up/down slope. Should be a fun variation to the track.
How's that offroad track coming along?
Old 09-24-2015 | 09:10 PM
  #25763
Not modest. Honest. I saw mention of shimming the diff on the thread when I first joined in 2008, but no one was terribly clear on the subject. For a bunch of guys who are willing to share, there are still a few spots where they got stingy.
Bob (Granpa) filled me in on the trick about three years ago. My only contribution was drilling an access hole for adjustments, which would probably be illegal under TCS rules, so if you do it and get caught, I don't know you.
Old 09-25-2015 | 07:16 PM
  #25764
sakadachi's Avatar
It's nice of you to show all the credits.
You taking the ideas and putting it together into tangible form with a twist deserves applause too. so thanks.
Old 09-25-2015 | 10:03 PM
  #25765
Does anyone know what sponge inserts are used on the tamiya premounted (1016) tires? Soft, medium, hard, super hard?
nsx2007 is offline
Old 09-25-2015 | 11:24 PM
  #25766
Hard inserts.
Old 09-27-2015 | 06:07 AM
  #25767
MrLesac's Avatar
Im excited that there is a new miata body for the M chassis cars, but what I don't understand is why Tamiya has chosen to use the M05 chassis underneath it. I wonder if the motor hangs out too far in the rear on the M06 chassis and thats why they went this route. I hope it fits the rwd chassis.
MrLesac is offline
Old 09-27-2015 | 06:48 AM
  #25768
sakadachi's Avatar
Looks nice.. I'd run it on my 4WD m-chassis.
Old 09-27-2015 | 08:07 AM
  #25769
KA2AEV's Avatar
Do you know the Tamiya Part number for the body only???
KA2AEV is offline
Old 09-27-2015 | 08:44 AM
  #25770
MrLesac's Avatar
Couldnt find info on the body set only, but I believe the part number for the whole car kit is 58624.
MrLesac is offline
