Like Tree3Likes
1/10th pan car
Old 02-24-2005 | 12:19 PM
  #8986
TOADYY's Avatar
Jack will be back....I was just stocking up since some of those bodies are hard to find.
TOADYY is offline
Old 02-25-2005 | 03:06 PM
  #8987
MarkA's Avatar
Originally posted by tjcdas1212
Foam Tire Truer
http://cgi.ebay.com/ws/eBayISAPI.dll...959761840&rd=1
I deleted your other posts in the forum saying the same thing but I’ll let this one stay with a warning that you can post your for-sale stuff in the for-sale forum and maybe one other relevant thread (in this case, I left it in here) – not ten threads at once.
MarkA is offline
Old 02-25-2005 | 04:50 PM
  #8988
MarkA's Avatar
Hey SoCal Guys - Something has come up for me at work and I'll have to miss tomorrow’s race - see you guys in two weeks.
MarkA is offline
Old 02-25-2005 | 05:21 PM
  #8989
MarkA's Avatar
I nominate vtl1180ny for one of the "best lines in a sig" here at RCTech:
Originally posted by vtl1180ny
Receipts hidden from my wife
MarkA is offline
Old 02-25-2005 | 06:51 PM
  #8990
Bounty Hunter's Avatar
Man....Hey Mark,
Is there anything special I need to know about the HPS shocks as in building technique?
Bounty Hunter is offline
Old 02-25-2005 | 07:26 PM
  #8991
MarkA's Avatar
Build/fill them just like you would if they were the VCS shocks but if you overfill/pressurize them, instead of taking them all the way apart and starting over, just unscrew the bottom about halfway, move the piston in and out a couple times, and when you retighten the bottom, they should feel good.
MarkA is offline
Old 02-26-2005 | 04:04 PM
  #8992
Smile to every one at socal
hay thx you guys for a great time last saturday hope to see you sooner than 3 years again
rebel106 is offline
Old 02-26-2005 | 04:25 PM
  #8993
vtl1180ny's Avatar
Hahahah... I showed it to her and she laughed.... I wonder if she ever looks into what I spend.... She has a brief idea of what things cost, but she has no clue what I own, my stuff is scattered between my garage, basement and shed....
vtl1180ny is offline
Old 02-26-2005 | 05:31 PM
  #8994
trackdesigner71's Avatar
Yeah Odds are you'd be on the couch if she ever found that out!
Anyway...any of you guys know what this would be:
http://cgi.ebay.com/ws/eBayISAPI.dll...958926716&rd=1
trackdesigner71 is offline
Old 02-26-2005 | 05:33 PM
  #8995
MarkA's Avatar
That is the Oval version of the L2 with a lazy-mans' battery mounting system.
MarkA is offline
Old 02-26-2005 | 07:23 PM
  #8996
MarkA's Avatar
Hey Robert – Glad we could help and that you’re posting here now.
MarkA is offline
Old 02-26-2005 | 08:00 PM
  #8997
Good to see some new faces around here. Hope everything is well with the SoCal bunch (I know you weren't there Mark, but Im sure the racing was still great)
Old 02-26-2005 | 10:11 PM
  #8998
FWR
I have been racing gas and electric sedans for the last few years. The local track is putting down some traction compound (grap pop) and foam tires seem to be working.
I have a RC10L3T that I want to try. Does anybody have a setup and recommended tires to use on a sealed asphault with grape pop parking lot road course.
FWR is offline
Old 02-27-2005 | 02:36 AM
  #8999
Pro ten Holland's Avatar
Moderator
The kit setup is where you want to start.
That should be:
Green compound front and rear tire,
30wt shock oil in all three shocks,
silver shock springs,
front ride height: 4mm, rear 4.5mm,
neutral toe angle,
camber: -1degree, set this so your tires wear flat,
caster shimms: one on each side of the upper suspension arm,
stock front springs (.020),
set preload on your center shock untill your rear pod lower plate is level with the main chassis, with the car with everything installed (battery, motor, electronics).
traction compound: rear full coating, front half of the tire, working your way from the inside to the outside, while spinning your tire. Let it soak in for around 15 to 30 minutes, when you use traction compound ofter on the same tires, this takes less and less time.
General tips:
switch front wheels left to right every other run to make them wear equal.
Keep track of your ride height and rollout, and adjust your car accordingly.
Let us know how it goes, maybe we can help you further. Anyway we're always interested to hear from more people driving these land-missile.
Pro ten Holland is offline
Old 02-27-2005 | 06:06 AM
  #9000
Default Its been a while
I took 6 months of racing off completly. I am back and have raced my wide pantoura, or Road Kill 10 for the last 3 or 4 races. I am doing terrible. I will probably switch back to the L2.5. It handled better last year. The track is new and much smaller. Its about right for a 1/12 scale so I am thinking mabye even an L3 insted.
My driving skills went right out the window.
They are actually thinking of starting a Pan car class because oval at this track has died out.
Nice to be back
David Root
David Root is offline
