New 1/8th 4WD basic class ???!!!
#63
Last weekend at the 2nd international clubrace of MORAC-Graz there did start 9 BURI-Racers and 1 Serpent 977e in E8. The winner was Martin Burger-Ringer who was best in all 3 final heats. The best laptime of the day by Marcel Knoeller was only 0.4 sec slower than with his Shepherd/Woldt Performance nitro car!
Look at the video, Marcel is pretty fast in the green car...
| + YouTube Video | |
#64
Thomas,
I'm back in the U.S. let us know how the cars doing during the ENS this weekend. I see no mention in Redrc as of yet. Super excited to put a chassis together.
More to follow...
More to follow...
#65
Hi,
my friend Tommy did a fine work in Ettlingen, sadly RedRC doesnt look at non sponsoring items.
But after the race days some of the very top drivers did try the BURI-Racers and they were surpriced of the performance and really had a lot of fun!
Many people did agree that this type of car will have a real chance to be established as some kind of stock class for 1/8th electric! Low costs and minimum maintenance are important arguments!
I did make some short videos...
| + YouTube Video | |
| + YouTube Video | |
#67
Which is strange, because many times when there was a demo class at other events i.e. F1 they had some mention.
Either way, this will be a great class if the TTB motors stay out, maybe Ernie P. at Trinity could offer some spec 1/8 2100Kv motors that would go we'll with the class given he is all for spec racing, and keeping cost down. The 480+$ TTB motors may be the cream of the crop for 1/8 on road, but you still need the ESC, and not everyone can afford that setup.
On the otherhand, Thomas what motors and esc's did you guys run, 2000 or 2100's.
#68
Hi,
the 120A escs of Hobbywing are really good working ones (SCT-Pro or WP-SC).
The motors we tried, but i am not fixed yet:
- Turnigy 2100 and 2300kV are the cheap ones but ok and well working
- SkyRC Toro X8 2250kV very powerful
- Hacker 2100kV very powerful but expansive
2300kV is really the maximum, the cars are very fast, I think 2100kV might be the the right choice to drive fast and have fun
#71
More Pics, OCD set in. Replaced the turnbuckles with Titanium ones, made a receiver box (courtesy of an MP9) and mounts for it. Soldered up the ESC. Mounted trued (Squared) Matrix tires, made a new tensioner for the front to relieve some of the tension on the drive belt (was causing tweak - left side was -3mm vs. the right). Body has come in - just waiting on the Batteries, then finish soldering the ESC install correct length antenna tube, and get some asphalt under it.
#72
So we put a few laps in, and have to say it drives very well. Son is still getting used to the power delivery - I will change the profile in the ESC, more on that later.
Put about a solid 15 minutes of running in - parking lot until body is finished then we will hit the track.
Motor never got above 125, and ESC stayed around ~98-101. Mind you these are all temps without the body on, and its 85 out with 61% humidity here.
The drive off the line is immediate and very direct although I noticed you have to watch the front to rear Diameter Bias on the tires. you can easily break the front loose once you get into the higher RPM's - I will play with the bias here in a bit.
It drives very well, reminds me of my Pro10 days, and the rear is similar to the chassis that had wide pods (Delta Villian, RC10L & maybe the TRC Pro 10).
The front end also reminds of kinda of the 200mm 4wd cars, having a one way setup, but the fronts reaction is different that 1/8 IC cars which I believe may be because of the lighter weight carried on that axle.
You get a bit of torque twist once you get the Motor to deliver its full potential too abruptly. If you use a smooth throttle delivery the torque does not over-ride the belt and cause the tweak front to rear. - I will see if the new throttle profile will help with that as well.
Sofar we can't wait to put some Foam down onto the track soon.
-only other updates since the last pics are the addition of the chassis protector tape, and the application of silicon spray to the belt to minimize dirt and debris.
#74
I know they just finished running in Italy at Mantua days.
27Likes
