Tamiya mini cooper >
Tamiya mini cooper
Like Tree295Likes
Tamiya mini cooper
Old 07-08-2015 | 05:55 PM
  #24436
AngryRog's Avatar
Originally Posted by Granpa
Roger, did you get a chance to run on the track?????? I heard they resurfaced it last week. Kevin said they had just laid it down.
No Granpa, I didn't go this past weekend. It was well past due for sure.
AngryRog is offline
Old 07-08-2015 | 06:17 PM
  #24437
I didn't either. I was going to make some changes to adjust the set up, but since they resurfaced, I'm going to leave it alone. I still have at least 5 sets of glued tires and am going to run those before switching to the no glue sets.
Granpa is offline
Old 07-08-2015 | 06:55 PM
  #24438
Laguna Bozo's Avatar
Default Glue/no glue
Oh, Grandpa. You're going to love this new no-glue rule. Traction role all over! New surface helps a little, but even white springs won't keep it on all four. Best I could do was 2-wheel the corners and hope it wouldn't hook or flip! Even Chuck saw air time. We need you out here...
Laguna Bozo is offline
Old 07-08-2015 | 07:17 PM
  #24439
Sounds like fun. I've got my workbench buried under a bunch of junk. That's another name for my wife's stuff as opposed to "good stuff", which is mine. I'll make a scouting trip out Saturday just to check out the new surface and see what's happening with the 21.5s. What's the "hot" esc now or will my old BLZ get me by?????
Feeling a little stronger now cause my last radiation treatment was 2 weeks ago. Maybe will work up the energy to finish my last project. Anyway, i'll see what you guys have been up to and pick some brains and compare notes.
Granpa is offline
Old 07-08-2015 | 08:13 PM
  #24440
sakadachi's Avatar
Originally Posted by Rodarbal
No recommendations as I'm using homemade stands as well. Looks like we're in the same boat as I need to make some modifications to fit my Tamiya M-cars better.
Here's the simple stand I made. Just a Futaba servo/receiver box with 2 balsa wood stuck on there with double sided tape.
The balsa wood prevents any scratches and also any rocking from the angled bottom. Picture of M03 from the front.
sakadachi is offline
Old 07-08-2015 | 08:21 PM
  #24441
sakadachi's Avatar
Originally Posted by M05 newbie
Man I'll try it all. We r here to learn and have fun. But really these rims are so mangled.
Here's what my wheels and foam inside looks like. I worked on this today while I was waiting for my batteries to charge.
Here is the finished picture of the used wheels I removed the tires from.
The tools I used. Olfa box cutter and small long nose. Nothing else.
As you can see, both the wheels and inserts are in good condition.
This is why I reuse them. Not a suggestion!
Old 07-08-2015 | 08:24 PM
  #24442
I really don't know what you're looking for, but $20 for a set of rims seems a bit much. There may be others who could weigh in.
Curious tho, are you also planning on gluing one side of the tires????? Seems to work for someone and I'm not going to argue with him about it. It doesn't pay to disagree. Get accused of all sorts of crap if you do.
He'll no...gluing both sides lol. My preference tho. But Ummm mm. How much should a set of 4 rims cost. Mind you the exchange on the Canadian dollar right now is murdering me. And this just happened lol.....took the foam out...tried to remove the rubber from rim...the rims broke and the one was cracked from impact from crashing. So another lesson learned is to not drive like a nut job and appreciate the road and how harsh it can be. I've really beat the living hell outta this thing so I'm gonna start to take better care of it.
M05 newbie is offline
Old 07-08-2015 | 08:39 PM
  #24443
I can't upload pics man 😂
Old 07-08-2015 | 08:41 PM
  #24444
Ya i would love to be able to do that. Only gluing one side tho lol. I glue both sides but I think I put way toooo much glue on them. And I smashed the living **** out of them so.....not doing that next time. Working on finesse now lol
Old 07-08-2015 | 08:51 PM
  #24445
sakadachi's Avatar
Yeah, it does take some level of finesse to do the work, but it's not difficult to do if you're pretty good with a knife.
Definitely glue both sides as needed. The tires I removed today came off a CupRacer (4WD). On that car I glued both sides on the front, but the rear was only glued on the face side. No issue throughout the life of the tires.
Old 07-08-2015 | 08:57 PM
  #24446
Keep forgetting about the non USA thing. If I'm gluing my own, I'll use the #51362--18 spoke chrome rim or the #51394---11 spoke white rim. They are $6 or 7 in the US. The premounts #1016 are $35 which really is the cost of the components, but do suggest you buy the components and glue your own. That way you can use contact cement to glue the ends of the inserts to avoid the insert problem the premounts have.
I know you did not ask, but I generally put everything together, work everything smooth then put a rubber band towards the side of the tire to be glued. I use the rubber band that the produce people use on broccoli. It's a good size and is a bit stronger than most. I use the regular thickness glue and work my way around the wheel by pulling the tire back, adding glue and proceeding around the wheel. The rubber band will pop the tire back into place or you can work it back if it doesn't. The regular thickness glue will give you the time to do this. I like the Losi brand but most regular will work. The thin runs all over and sets too quick.
As far as sources go, I primarily use TQracing and Stormer Hobbies. I think both will ship to Canada, but don't know about the tax situation. I think Monkeyracing is partial to TQ also.
Granpa is offline
Old 07-08-2015 | 09:06 PM
  #24447
sakadachi's Avatar
I pull back the tire bead, drop just regular ca I bought at Target (CrazyGlue?) and press gently allowing capillary action to do its work. I can usually get about 75-90 degrees applied with one drop of ca. Rotate tire in my hand and repeat. At the very end I stream a light application along the bead 360 degrees.
Then as Granpa mentioned, rubber band for 10min or so.
Old 07-08-2015 | 09:30 PM
  #24448
niznai's Avatar
Isn't this the Sabre Mini thread? lol
Nope. It's the saber rattling thread.
Well I'm about to try it becaus that's all I have right now. For a parking lot party it'll be ok for now. I'm learning right. And I have an itch to tinker so bad and I don't have my gears to rebuild the whole thing until Friday so I'll see what happens with the tires. So I should look at soft for the pavement right now. Thanks for the insight Granpa. I'll take some pics and post how the tire change goes and how badly these wheels are cooked lol. I beat the hell outta this thing...now I know not to lol.
Question Granpa. What are some good quality wheels that are on the tougher side. Looking at tamiya reinforced wheels for the mini. Ebay has em for about 20 a set roughly.
Not sure what reinforced rims you're looking at, but if they're the carbon ones, look elsewhere. They're exceptionally brittle. Save your money, it's enough I wasted mine.
Them ones:
https://www.tamiyausa.com/items/radi...r-wheels-53341
Avoid.
niznai is offline
Old 07-08-2015 | 09:41 PM
  #24449
sakadachi's Avatar
Actually I did work on my SabreFD Mini today. I changed rear camber to -1.2 and the rear has finally stabilized to my liking.
I also added one wheel weight on the right side of the chassis next to the motor the other day. Excellent advise by Calvin to add weight to the front.
I'm real happy with how the car runs. But my V2 is still smoother (and quieter!) and is the king for me.
Old 07-08-2015 | 10:08 PM
  #24450
Last week did a full shock rebuild on my M05 swift body...pulled the dampers out, refilled with oil, hard springs up front, medium on rear, put new shimizu tyres on, hard up front medium on rear.
Hit the track and as soon as I turn a corner the car spins 180 on itself. Tried all kinds of shock adjustments including winding them fully down to eliminate as much play as possible. Same problem. Put hard springs on the rear as well as front, problem started to subside a little but too much turn it still spun.
Then went back to my old rear tyres (also medium) and the problem pretty much went away, except it was grip rolling. I adjusted the Tx settings and swapped grip rolling for slow cornering. I'm now wondering if the medium tyres really are medium...
Can't figure out what else might be the problem and have another meet tonight on the same setup, so expecting more of the same tonight...Finicky things lol.
Depth_Charge is offline
