Tamiya mini cooper
I am glad my wife and I did not finish the basement. It was supposed to be finished long time ago when we bought the house, but kept putting it off, then kids, then no time.
TA03 ball diff'' will help w/ keeping corner speed (if you don't already have it installed)
...my recommendation is go easy on throttle ...feather it, don't jab it. Also try to roll through corners rather than brake. I find that racing the mini is more about keeping it smooth around the track ...slow and steady is much better than aggressive and jabbing at the throttle.
Yes, thanks for reminding me I too run ball diffs in my V2.
I couldn't believe Tamiya did not include this in the V2 package.
I have both TA03 and M05 ball diffs. I will mention that the MantaRay ball diff's pressure plate splines to the outer drive cup broke within 6months.
I only run the M05 ball diffs now.
I couldn't believe Tamiya did not include this in the V2 package. I have both TA03 and M05 ball diffs. I will mention that the MantaRay ball diff's pressure plate splines to the outer drive cup broke within 6months.
To 3219toon, the above was the second part to my answer to your query.[/QUOTE]
Thanks for the help Grandpa, I'll have a go at your suggestions.
I have been running indoors on carpet and the car went OK. We've moved outside now on a school yard with very little grip. I kept the same set up, using 60D Radials up front and M Grips on the back. I did notice that the Radials are now slicks which probably indicates how much grip I was actually getting, causing the grip roll.
Thanks again, I make the changes and get back with how I get on. Might be a few weeks though as I'm going to me missing a race or two.
Craig,
No chemicals used on my chassis or the other two with the same issues. I would have to say the thinner lower chassis and redesign have made the chassis a little more susceptible to damaging easily.
I have found the more openings in the chassis, also allow the ingress of small pebbles and dirt, which we cause the middle gear to strip quickly. I have found blutack and battery tape my best friend to combat this.
A few mini drivers here in Aust are going back to the original MO5 which did not have theses issues. Even my dremeled MO5 chassis, that fits asquare battery pack did not have these problems.
I also did not like the MO6 suspension pins on my MO5. I found I needed to run longer shocks with softer oil,which made the car horrible to drive. I reverted back to the standard shocks and shock positions.
However we run Ride inch ups as our control tyre and I have found running the same oil front and rear, with harder springs on the rear and higher rear ride height to work best for me.
Are you referring to like the cross braces? If so, they help especially taller bodies like the Rover Mini bodies from swaying more than it should during cornering and switchbacks. Makes the car respond faster to your driving inputs.
Thanks Sakadachi. I appreciate the one you take to respond.
Thanks again, I make the changes and get back with how I get on. Might be a few weeks though as I'm going to me missing a race or two.[/QUOTE]
The tires are the main problem. While the M-Grips have more grip on carpet, they don't on asphalt. Try running the M-Grips up front and the S-grips on the rear. That should give you a horrible push tho with any suspension settings. Tires are 75% of chassis tuning.
We run the S-Grips all around and my suggestions were based on that tire selection. Because of the rules we run here, that's pretty much our only option. If you can run other tires, for 60D size tires, the Pit Shimizu slick with the Tamiya hard foams are terrific. Try the 456 or 454 up front and the 452 in the rear. If you go this route, glue the sets separately cause once out of the package there are no markings to tell one from the other.
If you can use the 55D tires, my control tire has been the Sweep premounts. They seem to work on both carpet and asphalt. Use a harder compound up front and a softer one in the rear. For low grip asphalt tho, my go to tire was the Atomic. Unfortunately, there are a lot of 55D tire choices out there with a myriad of insert and wheel combinations. Calvin is a wealth of info on these tires and would be the guy to ask. Not knocking the guys here, but the Australians have been using these for many years and have a wealth of data that we're not privy to.
Yes, thanks for reminding me I too run ball diffs in my V2. I couldn't believe Tamiya did not include this in the V2 package.
A little off-topic, but I should start building my SabreFD FWD, huh?
This is supposedly my project for Father's Day coming up.
The AWD version looked too similar to my M-Four so went FWD this time as I've never tried a FWD with open gear box.
Btw do you guys use MIP hex wrenches? Due to unexpected (by me) popularity here, my kids bought me a 3 piece driver bit set.
Should come in handy for the build.
Okay, back to Tamiya m-chassis.
The AWD version looked too similar to my M-Four so went FWD this time as I've never tried a FWD with open gear box. Btw do you guys use MIP hex wrenches? Due to unexpected (by me) popularity here, my kids bought me a 3 piece driver bit set.
Should come in handy for the build.Okay, back to Tamiya m-chassis.
Yes, the yellow transparent handles look pretty dated for sure!
The ones I am getting are just the bits though to use on my Panasonic driver and Wera ratchet driver handles.
If I could afford a full set of MIP/Thorpe drivers, I'd do it in a heartbeat. My Arrowmax are good, but not compared to MIP.
BTW: has anyone tried the Yeah Racing wide span suspension set? I'm wondering if it's made of the same cheese as their other suspension components, or if it's any good. Could be an interesting addition to the Xevo.
295Likes
