tekin rsx esc
Old 06-01-2015 | 09:30 AM
vito's Avatar
Default tekin rsx esc
how to put a switch back on i cut it off by misstake its the on and off on
vito is offline
Old 06-02-2015 | 11:35 AM
Randy_Pike's Avatar
Team Tekin
if there's enough lead you can solder a new one back on. We sell the part by itself.
Randy_Pike is offline
Old 06-03-2015 | 11:05 PM
Run without the switch. Just make sure you don't cross the streams.
rbk1115 is offline
Old 08-24-2015 | 12:50 PM
Does anyone know if its ok to run the RSX in a pro4 truck with a 2 pole motor like the orion guys do with the r10.1 pro..
CurtDawg is offline
Old 08-24-2015 | 03:19 PM
Dan.J's Avatar
Randy told me no, I guess its the weight of the truck more than the motor used they are worried about. With the Orion you can run basically what ever motor you want but good luck keeping a fan on it, Personally I went back to a Rx8 Gen2 in my Pro4, other than having to replace the case on occasion they have been solid for me and the footprint is a little larger with the RX8 but they are very light for a 1/8 scale ESC.
Dan.J is offline
Old 08-24-2015 | 03:34 PM
Randy_Pike's Avatar
Team Tekin
No, it's going to be too heavy. The Rx8 dominates this class for a reason, they never thermal.
4wd SC is the highest load in r/c racing right now, don't take it for granted and try to run something that's on the edge.
Old 08-24-2015 | 05:25 PM
Would it be safe to run 17.5 blinky in 2wd S.C. truck with out any issues using the RSX?
Andy Koback is offline
Old 08-24-2015 | 08:09 PM
Grizzbob's Avatar
Super Moderator
Considering that I've done that with an older Gen 1 RS(not the RS Pro) & had no problems whatsoever, I'd think the RSX should handle that just fine....
Grizzbob is offline
Old 08-24-2015 | 09:13 PM
nexxus's Avatar
Super Moderator
The only 1/10 size ESC I have seen that can handle a 4wd SCT without getting too unhappy is the Hobbywing V2 (sensorless only though) and the Dualsky XC870TF (Small but chuck it in blinky mode and it'll run a 4wd sct all day.
nexxus is offline
Old 08-25-2015 | 08:13 AM
Wondering cause instructions say something about a 5# weight limit. Truck weighs just about that race ready.
Old 08-25-2015 | 08:10 PM
Grizzbob's Avatar
Super Moderator
I hadn't heard about anything on weight limits(but then again, I never weighed my Associated FT SC10 when I was racing it), but I'd still think if a gen 1 RS(non-pro) can handle it with a 17.5, then the RSX certainly should(but I've been wrong before).....
Grizzbob is offline
