Tekno RC SCT410.3 Thread >
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree219Likes
Last edit by:
Print Wikipost
Old 05-25-2015 | 10:35 PM
  #931
Barillms's Avatar
Will +3 SC10 4x4 wheels put me wider than ROAR rules? All my wheels are DE +3mm. What is the max legal width?
Barillms is offline
Old 05-25-2015 | 11:42 PM
  #932
Matthew_Armeni's Avatar
The max legal width is 296mm. For 4x4 short course it is supposed to be measured at the axle centers but I haven't raced anywhere where that's been the case. Most places measure overall width (which can be affected by camber and toe angles) with a big gauge/cutout, or they place the truck in a box and see if it rolls out.
Either way I don't see the +3s being legal, even if you ran very little camber and toe.
That being said, unless you're running at an actual ROAR event, I wouldn't worry about it, just run the +3s.
Lastly, I'm assuming that all your tires are already glued to these +3 rims
Matthew_Armeni is offline
Old 05-26-2015 | 06:09 AM
  #933
Originally Posted by Tijuana_Taxi
I would try lowering the center diff weight to allow the front to pull a little more. All depends on driving style but 10/10/7 might be a little high all the way around for anything except high bite stuff.
This weekend I finally got to race my truck for the second time. I had the right tires, tried laying my rear shocks down, changed my anti-squat (flattened my arms) and the rear was still a little loose. (I noticed that, as someone posted, the rear was more loose off-power with flatter arms)
So I'll be changing my anti-squat back to how it was and lowering my center diff fluid. Do you think that putting 7k in it will be enough of a change? Or should I put 5k in it?
Regardless, I placed 5th in the a-main with this truck my 2nd time ever running this class. It was a pretty big memorial day race with 3 full heats of CORR truck and I beat some really talented drivers so, even though the truck isn't quite where I want it yet, it is still amazing and the steering and stability it has is incredible.
louie8269 is offline
Old 05-26-2015 | 06:18 AM
  #934
Cain's Avatar
in general with the older vehicle when I had rear traction issues the thing that seemed to help the most was going lighter on the rear diff fluid. I was down to 2K at one point and liked it alot.
Cain is offline
Old 05-26-2015 | 06:36 AM
  #935
bds81175's Avatar
Moderator
Removing the rear brace planted the rear end too.
bds81175 is offline
Old 05-26-2015 | 06:41 AM
  #936
Both my rear brace and center diff brace were removed as well.
Old 05-26-2015 | 08:32 AM
  #937
Barillms's Avatar
What springs come stock on the 410.3?? What springs should I buy to have in the arsenal?
Barillms is offline
Old 05-26-2015 | 11:15 AM
  #938
Stand your rear shocks back up (out on the tower) if you're loose in the rear. Laying them down is most likely what caused the loose off power feeling, not taking out antisquat. Less antisquat will give you more rear traction into a turn because it's allowing the suspension to be more effective through the turn. To exaggerate my point, imagine if you ran 90° of antisquat (arms vertical)- through a turn, the suspension wouldn't be able to compress and the car would just slide. This applies to accelerating in a straight line as well. With the arms vertical, the suspension can't compress and the car would do a wheelie if there was enough traction.
Old 05-26-2015 | 12:04 PM
  #939
teknorc's Avatar
Originally Posted by Orion_2kTC
This weekend I noticed that when I'm at a hard steering point my wheels are rubbing so I had to back off my EPA to make sure it didn't. Everything appears tight but I lost a TON of steering since I had to make such drastic changes to my EPA. What can I look for that may fix this?
I wouldn't worry about this at all. Put the steering EPA back where you want it and let it rub a little. The original truck was like this as well and we didn't have any trouble with it. We wanted to maximize the strength of the arm which is why it's a little thick at that spot.
teknorc is offline
Old 05-26-2015 | 12:15 PM
  #940
Shawn_S's Avatar
Sometimes luck overcomes skill. I only had one set of Blockades for both qualifiers and the main. They were well toasted after Q2. Good race, truck is still a little snap loose, but getting better and better.
I'm the pink/white truck.
+ YouTube Video
Shawn_S is offline
Old 05-26-2015 | 12:35 PM
  #941
TheCore's Avatar
great race. that one was a lot of fun to watch.
TheCore is offline
Old 05-26-2015 | 01:10 PM
  #942
dave-man's Avatar
Originally Posted by edonsohc
was a slow blinking green led. I believe that is thermal.
From what I can find:
Slow blinking green is thermal. Red blink blink is low voltage.
http://www.hobbywing.com/uploadfiles...-09-SCTPRO.pdf
dave-man is offline
Old 05-26-2015 | 01:19 PM
  #943
edonsohc's Avatar
and the thermal can't be shutoff either. dumb. I understand from a warranty aspect why it can't be shutoff, but dang.
edonsohc is offline
Old 05-26-2015 | 03:22 PM
  #944
So what does remove rear brace really do on a low traction track i thought having the brace on to make it don't
coombes is offline
Old 05-26-2015 | 03:35 PM
  #945
Default Body Post
Anyone successfully used proline body mounts on SCT410? If so, did you use the proline body posts or cutoff the top of the Tekno body posts? Just wondering. The angles on the proline mounts don't match the body angles.
qstorm777 is offline
